  3. Problem wuth tool configuring after installation (IC6.15...
  • Replies 12
  • Subscribers 136
  • Views 25026
Problem wuth tool configuring after installation (IC6.15)
Pavel47
Pavel47 over 14 years ago
1st time I've installed IC6.15 on the RHEL5.4. Everything was OK.
For some reasons I nedded to change the OS for RHEL6.2. This time installation was OK, but next step - tool configuration - failed.
Inside of the iscape_log file I've found nothing, that I could explore to debug the problem. Below I've put the extract from escape log.
So, I've 2 questions:
1. Is configuration phase crucial for the tool functionnality ?
2. How can I debug this issue if there is no consistent diagnostic info ?
Thank you in advance.
Pavel.
P.S. Extract from escape_log (final part):
Running Configuration of components in GUI.
Running:/bin/sh /opt/Cadence/IC615/install/tmp/slconfig.sh CSRCO07.24-p031lnx86
Error::Return Value is:1
Running:/bin/sh /opt/Cadence/IC615/install/tmp/slconfig.sh amsEnv06.15-p003lnx86
Running:/bin/sh /opt/Cadence/IC615/install/tmp/slconfig.sh DFII_ncvhdl64b09.20-s030lnx86
Running:/bin/sh /opt/Cadence/IC615/install/tmp/slconfig.sh CSRCOIndep07.24-p031
Running:/bin/sh /opt/Cadence/IC615/install/tmp/slconfig.sh lfvhdComp02.85-a002lnx86
Running:/bin/sh /opt/Cadence/IC615/install/tmp/slconfig.sh DFII_ncvhdl09.20-s030lnx86
Running:/bin/sh /opt/Cadence/IC615/install/tmp/slconfig.sh oaRedist22.41-p004lnx86
Running:/bin/sh /opt/Cadence/IC615/install/tmp/slconfig.sh ihdl06.15-p003lnx86
    By the way, RHEL6 is only supported from IC615 ISR12 onwards. There are some serious issues (caused by an OS incompatibility in some of the low level C functions) which we had to correct for. These appear to only affect running in 64 bit mode (eg virtuoso -64 or setting CDS_AUTO_64BIT); there's a solution on this on Cadence Online Support.
    If you'd have run checkSysConf it would have told you that it wasn't supported. checkSysConf from later ISRs of IC615 would have told you that some of these packages were missing (it probably should check them all though).
  • venkat379
    venkat379 over 11 years ago
    I know this is old post. still for those are having this problem, the solution is yum install xterm (need to install xterm package)
