  3. Problem wuth tool configuring after installation (IC6.15...
  • Replies 12
  • Subscribers 136
  • Views 25301
Problem wuth tool configuring after installation (IC6.15)
Pavel47
Pavel47 over 14 years ago
1st time I've installed IC6.15 on the RHEL5.4. Everything was OK.
For some reasons I nedded to change the OS for RHEL6.2. This time installation was OK, but next step - tool configuration - failed.
Inside of the iscape_log file I've found nothing, that I could explore to debug the problem. Below I've put the extract from escape log.
So, I've 2 questions:
1. Is configuration phase crucial for the tool functionnality ?
2. How can I debug this issue if there is no consistent diagnostic info ?
Thank you in advance.
Pavel.
P.S. Extract from escape_log (final part):
Running Configuration of components in GUI.
Running:/bin/sh /opt/Cadence/IC615/install/tmp/slconfig.sh CSRCO07.24-p031lnx86
Error::Return Value is:1
Running:/bin/sh /opt/Cadence/IC615/install/tmp/slconfig.sh amsEnv06.15-p003lnx86
Running:/bin/sh /opt/Cadence/IC615/install/tmp/slconfig.sh DFII_ncvhdl64b09.20-s030lnx86
Running:/bin/sh /opt/Cadence/IC615/install/tmp/slconfig.sh CSRCOIndep07.24-p031
Running:/bin/sh /opt/Cadence/IC615/install/tmp/slconfig.sh lfvhdComp02.85-a002lnx86
Running:/bin/sh /opt/Cadence/IC615/install/tmp/slconfig.sh DFII_ncvhdl09.20-s030lnx86
Running:/bin/sh /opt/Cadence/IC615/install/tmp/slconfig.sh oaRedist22.41-p004lnx86
Running:/bin/sh /opt/Cadence/IC615/install/tmp/slconfig.sh ihdl06.15-p003lnx86
    Pavel,
    You probably don't strictly need to run the configuration, but the above shouldn't happen. Maybe there's some package missing on your machine? I just ran it successfully on a RHEL6.1 machine (I'd be surprised if 6.2 was significantly different).
    BTW, RHEL6 is not yet supported for IC615 - hopefully we should be supporting it from IC615 ISR12 onwards.
    Perhaps you should contact Cadence Customer Support?
  • Pavel47
    Andrew,
    Thank you for response. It seems that my OS in some manner "isn't understood" by the cadence tools. Here is output of the command  checkSysConf IC6.1:
    [Copyright 2002-2010] Cadence Design Systems, Inc. All rights reserved.
    This  program and online  documentation  may not be copied, modified,
    re-published, uploaded,  executed, or  distributed in any way, in any
    medium, whether in whole or in part, without prior written permission
    from Cadence Design Systems, Inc.
    ============== checkSysConf:  Version 3.16 ====================
    Configuration checks failed, status is: FAIL
    checkSysConf cannot reliably parse your systems /etc/redhat-release file
    It would appear that the file is non-standard and does not contain release
    information in the standard readable format.
    The contents of your /etc/redhat-release is listed below between
    <RELEASE_FILE> tags.
    A 'correct' release file should have only one line of content, containing
    version information in a standard format.
    <RELEASE_FILE>
    Red Hat Enterprise Linux Client release 6.3 (Santiago)
    </RELEASE_FILE>
    Please check/correct your /etc/redhat-release file and try again.
    There is no OEM datafile for IC6.1 for the Linux platform.
    Valid OEM images are :
    foreach: No match.
    Moreover I'm not sure, that license manager is run. Here is output of the lmstat:
    [root@Missouri PIXIE-III]# lmstat
    bash: /opt/Cadence/IC615/tools/bin/lmstat: /lib/ld-lsb.so.3: bad ELF interpreter: No such file or directory
    Pavel.
  • Pavel47
     Last time I installed some packages, that probably damaged installscape-related files. Actually I cannot run InstallScape:
    [root@Missouri iscape]# sh ./bin/iscape.sh
    Initializing InstallScape using JVM at /opt/Cadence/InstallScape/iscape/runtime/LNX86/bin/java. This might take some time...
    No protocol specified
    Exception in thread "main" java.lang.InternalError: Can't connect to X11 window server using ':0.0' as the value of the DISPLAY variable.
        at sun.awt.X11GraphicsEnvironment.initDisplay(Native Method)
        at sun.awt.X11GraphicsEnvironment.access$100(Unknown Source)
        at sun.awt.X11GraphicsEnvironment$1.run(Unknown Source)
        at java.security.AccessController.doPrivileged(Native Method)
        at sun.awt.X11GraphicsEnvironment.<clinit>(Unknown Source)
        at java.lang.Class.forName0(Native Method)
        at java.lang.Class.forName(Unknown Source)
        at java.awt.GraphicsEnvironment.getLocalGraphicsEnvironment(Unknown Source)
        at sun.awt.X11.XToolkit.<clinit>(Unknown Source)
        at java.awt.Toolkit$2.run(Unknown Source)
        at java.awt.Toolkit.getDefaultToolkit(Unknown Source)
        at com.khanpur.installer.gui.InstallerUI.main(InstallerUI.java:88)
    That just suggests that it can't open an X window because it can't contact the X server. I get that if I don't have permissions to access the display - so this might just need you to do "xhost +" or something before trying to run it.
    As I said, it's an unsupport platform, so checkSysConf won't be able to check required patches (because there's no list, because it's not supported).
    As I said, contacting customer support is your best bet.
  • Pavel47
     Andrew,
    I've advanced in my investigations - I think it's isn't Cadence issue, but rather RHEL. Obviously the problem comes from hostname. When I worked with RHEL5.2, there were no specific hostname - the output of the hostname command was localhost.localname or something like this. When I intalled RHEL6.2 I specified hostname - now it's Missouri. But surprisingly this hostname isn't completely recognized by system. When I do hostname, it's Ok, but ping doesn't work:
    [Pavel@Missouri ~]$ hostname
    Missouri
    [Pavel@Missouri ~]$ ping Missouri
    ping: unknown host Missouri
    Moreover when I force to run license manager and see log file, I constate that my hostname is unknown:
     $CDS_ROOT/tools/bin/lmgrd -c $LM_LICENSE_FILE -l /var/log/ic615_debug.log
    Here is extract from .log file:
    19:11:29 (lmgrd) The license server manager (lmgrd) running as root:
    19:11:29 (lmgrd)     This is a potential security problem
    19:11:29 (lmgrd)     and is not recommended.
    19:11:29 (lmgrd) Unknown host: Missouri
    19:11:29 (lmgrd) EXITING DUE TO SIGNAL 33 Exit reason 1
    I searched on the inet for the similar issues and found following solution - add my hostname in the /etc/resolv.conf.  I tried it, but without success.
    Regards.
    Pavel.
    Pavel,
    What do you have in /etc/hosts ?
  • Pavel47
     Andrew,
    Here is hosts content:
    127.0.0.1   localhost localhost.localdomain localhost4 localhost4.localdomain4
    ::1         localhost localhost.localdomain localhost6 localhost6.localdomain6
    You probably need to ensure the machine name is in the file. For example:
     127.0.0.1  Missouri Missouri.whateveryourdomainnameis localhost localhost.localdomain
  • Pavel47
    Finally I decided to return to RHEL5.4.
    It's Ok once more.
    Thanks Andrew.
  • Matrixesque
    Matrixesque over 13 years ago
    Hey man, this might be far out in left field, but I had a problem with my IC6.15.011 on RHEL 6.3 and this was one of the symptoms I was Googling. Dunno if this'll help, but maybe it'll help someone like me. My problem was that I could open a new Virtuoso Schematic Editor XL window, but when I tried to instantiate an instance, the system would hang and I'd see the following error message in the /root/CDS.log console:
    > *WARNING* ddsInvokeBrowser: Unable to connect to library browser (60 tries)
    Someone online suggested taking a look at the Library Path Editor and when I tried to open this application I would get the following error message in the /root/CDS.log console:
    > /root/cadence/installs/IC615/tools/dfII/bin/32bit/libManager: error while loading shared libraries: libXi.so.6: cannot open shared object file: No such file or directory
    Well, I had had to install about a million 32-bit packages (to wit: libGL.so.1, libGLU.so.1, libelf.so.1, libXrender.so.1, libXp.so.6, libXi.so.6, libXext.so.6) on my 64-bit system manually just to get InstallScape and then Cadence to launch, so perhaps this was just one more I needed. I installed the binary 32-bit package for libXi from here:
    http://pkgs.org/centos-6-rhel-6/centos-rhel-i386/libXi-1.3-3.el6.i686.rpm/download/
    After that, the Library Path Editor would launch, but it would prompt for the creation of a new cds.lib file. Smelling a rat, I cancelled the dialog and went back to the Virtuoso Schematic Editor XL cell view and tried to place another instance, browsing for the appropriate library once again. This time, presto! The Library Browser - Add Instance dialog popped up and all the basic libraries were there! Problem solved! (for now)
    Hooray for hidden library dependancies that only show up during runtime with totally worthless error messages! This whole installation has been a nightmare. For the record:
    > uname -a
    Linux localhost 2.6.32-279.11.1.el6.x86_64 #1 SMP Sat Sep 22 07:10:26 EDT 2012 x86_64 x86_64 x86_64 GNU/Linux
