  3. almSetPropMappingList Usage Issue
  • Subscribers 133
  • Views 14926
gavinc
gavinc over 14 years ago
I create my own simulation view and use ADE skill command almSetPropMappingList to setup its CDF property mapping field.
I list my command as below.
almSetPropMappingList(lib cell almGetPropMappingList(lib cell ?tool "hspiceD") ?view "hspiceD_subckt")
This command works fine in IC615 and I can correctly change my instance parameter with above setting.
However, the same command can't work in IC5141. Is this the limitation of IC5141?
 Gavin
    Gavin,
    I filed a CCR on this a while back, and it was fixed in IC614 - in all releases prior to that, the view-specific CDF settings for propMapping (as set by almSetPropMapping) were ignored during netlisting. So It's a limitation of IC5141, yes.
  • Quek
    Quek over 14 years ago
    Hi Gavin
    There was a bug with almSetPropMappingList and it was fixed in IC614. So unfortunately, it will not work with IC5141.
    Best regards
    Quek
  • gavinc
    Hi Andrew & Quek,
    Now I know it clearly. Thank you for your help.
    Gavin
