  3. Generated schematic using import option is a complete m...
  • Subscribers 133
  • Views 15975
Generated schematic using import option is a complete mess
MOS007
MOS007 over 14 years ago
Hello everyone,
When I import the spice netlist using the import option the tool generates a schematic which is completely jumbled up. Is there any way to tell the tool to generate the schematic in a particular order?
Info: I noticed that the order and name of the transistors doesn't affect (if the .cdl or spice netlist contains only mos transistors) the schematic generation.
MOS007
  • Quek
    Quek over 14 years ago
    Hi MOS007
    No, there is no such option. spiceIn has an analog schematic option which will allow it to arrange the transistors more nicely but it is not possible to force it to do the arrangement in a specific manner.
    Best regards
    Quek
  • MOS007
    Thanks Quek for the info. - MOS-007
  • MOS007
    Hello Quek,
    Do you know a technique where I can get rid of the measurements in the layout window? If I use a ruler (keyboard shortcut = 'k') to measure the widht of the layers the measurement gets stuck on the screen. I need to save and reopen the layout to get rid of the ruler. Is there a way to get rid of it without closing the layout window and reopening it.
    MOS007
  • John Regan
    John Regan over 14 years ago
    Ruler Bindkeys: Create Ruler = Shift+k Delete Ruler = Shift+K See layout menu --> Tools John
  • MOS007
    Thanks John. I hadn't even seen that option :P
