  3. Calculator function that returns the sign of the number
  • Views 21126
acbalbason
acbalbason over 14 years ago
Hi All,
I was wondering if there exists a way or a function from the calculator which will return if the number is positive or negative. Or at least something close to that.
Alfonso
  • skillUser
    skillUser over 14 years ago
    Hi Alfonso,
    There is a SKILL function, plusp(), that you can use to test if a number is positive or not - it returns 't' for positive numbers, and 'nil' for 0 or negative numbers.
    Hope this is what you are looking for?
    Lawrence.
    If you want this to work on waveforms - to give (say) 1 or 0 depending on whether it's positive or not, you could use:
    abApplyToWave(lambda((val) if(plusp(val) 1 0)) myWaveform)
    where myWaveform is your expression. This uses this code below. If the lambda frightens you, you could do:
    procedure(abPositive(val)
      if(drIsWaveform(val) || famIsFamily(val) then
        abApplyToWave('abPositive val)
      else
        if(plusp(val) 1 0)
    And then use:
    abPositive(yourExpression)
    This will work if it's a number or a waveform - it uses abApplyToWave inside. I wrote the example above in C syntax to make it easier if you're not familiar with the LISP syntax - but the abApplyToWave is written using LISP-style. See the comments at the top.
    /* abApplyToWave.il
    Author     A.D.Beckett
    Language   SKILL
    Date       May 24, 2011
    Modified   A.D.Beckett
    By         May 31, 2011
    Function to apply a unary function to every element
    in a waveform. For example:
    abApplyToWave('round waveform)
    Can also add to the Skill User Defined Function using:
    abRegApplyToWaveSpecialFunction()
    SCCS Info: @(#) abApplyToWave.il 05/31/11.17:24:41 1.2
    *                  (abCreateApplyToWaveForm)                   *
    *      Create the form needed to enter the function name       *
    (defun abCreateApplyToWaveForm ()
      (let (func)
        (setq func (ahiCreateStringField
                     ?name 'func
                     ?prompt "Function"
                     ?value "round"
        (calCreateSpecialFunctionsForm
          'abApplyToWaveForm
          (list (list func 0:0 280:20 140))
    *               (abApplyToWaveSpecialFunctionCB)               *
    *            Callback for the registration function            *
    (defun abApplyToWaveSpecialFunctionCB ()
        ?formSym 'abApplyToWaveForm
        ?formInitProc 'abCreateApplyToWaveForm
        ?formTitle "Apply to Wave"
        ?formCallback "abApplyToWaveFormCB()"
    *                       (abApplyToWaveFormCB)                       *
    * Callback for the form. Bit complicated because need the arguments *
    * to be with the waveform not first, and with a single quote before *
    *                        the function name.                         *
    (defun abApplyToWaveFormCB ()
      (let (form)
        (setq form (hiGetCurrentForm))
        (calCalcInput
          'expression
          (sprintf nil "abApplyToWave('%s %s)"
                   (concat (getq (getq form func) value))
                   (calGetBuffer))
        t
    *                (abRegApplyToWaveSpecialFunction)                *
    * Function to actually register the user defined special function *
    (defun abRegApplyToWaveSpecialFunction ()
      (calRegisterSpecialFunction
        (list "abApplyToWave" 'abApplyToWaveSpecialFunctionCB)
      t
    *                    (abApplyToWave func arg)                     *
    *  And finally, the function that does the work. You give it the  *
    *  name of a unary function (takes one argument) which works on   *
    * numbers, and then this is applied to all members of a waveform. *
    *                      Handles families too.                      *
    (defun abApplyToWave (func arg)
      (cond
        ((numberp arg) (funcall func arg))
        ((drIsDataVector arg) (vecMap 'abApplyToWave func arg))
        ((drIsWaveform arg)
         ; Create new waveform, but transfer units if not set on
         ; new waveform already. This ensures plotting on the same y-axis
         (let (new yVec)
           (setq new (wfMap 'abApplyToWave func arg))
           (setq yVec (drGetWaveformYVec new))
           (unless (getq yVec units)
             (putpropq yVec (getq (drGetWaveformYVec arg) units) units)
           new
        ((famIsFamily arg) (famMap 'abApplyToWave func arg))
        (t
          (error "abApplyToWave: can't apply %L to %L\n"
                 func arg)
