  3. skill command to get the current library name
  • Views 19437
Meny Lea
Meny Lea over 14 years ago
Im looking for a  skill command that can return the current library name that appear on the library manager
top left field - "Library".
without open any schematic/layout window ...
thx
meny
    Meny,
    There isn't really a concept of the "current library" in the library manager - it's not intended to be used as a browser.
    If you want to have a UI which selects a library, you should use the ddsSyncWithForm() function. Alternatively, you can customize the library manager to add a menu or popup menu which will cause some action to be triggered based on the selected library (or lib/cell/view). This is covered in the Library Manager documentation.
  • Meny Lea
    Thanks andrew,
    I will take the secound option.
    I wrote a sshort simple GUI that suppose to be open from the lmgr:
    ; create a new pull-down menu, to contain the toggle example
    lmgrCreateMenu("RF_Menu" '(("label" "RF")))
    ; Add the new pull-down menu into the menu banner
    lmgrAddMenuItems("menuBar" "" '("RF_Menu"))
    lmgrCreateMenuItem("sortutility" "simple"
    '(("label" "sort Gui")
    ("callback" ("sort_by_date"))
    ; Create a pull-down to contain the 1 radio options
    lmgrCreateMenu("RadioPulldown" '(("label" "Sort by date utility")))
    ; Add the radio options to the pull-down. Note that radio options must
    ; be in their own submenu
    lmgrAddMenuItems("RadioPulldown" "" '("sortutility"))
    lmgrAddMenuItems("RF_Menu" "" '("RadioPulldown"))
    procedure( sort_by_date()
    MLsort()
    printf("yes\n")
    hiDisplayForm(ADsort)
    procedure( MLsort()
    ADsort = hiCreateAppForm(
    ?name 'ADsort
    ?formTitle "Sort library cells by date"
    ?buttonLayout '(OKCancelDefApply)
    ?buttonDisabled '(Apply)
    ?dialogStyle 'modeless
    ?initialSize 330:780
    ?minSize 330:780
    ?maxSize 330:550
    ?unmapAfterCB t
    ?dontBlock t
    ?mapCB   "nil";; in start up
    ?callback  list("nil");; in close - OK or apply
    ;?help
    ?fields list(
    list( hiCreateStringField(
    ?name 'srcLib
    ?prompt "Library"
    ?defValue "rftc55u__sim_menyl "
    ?callback "ddsUpdateSyncWithForm()" )
    20:20 260:025 80
    list( hiCreateButton(
    ?name 'SrcBrowseBtn
    ?buttonText "Browse..."
    ?enabled t
    ?callback "ddsSyncWithForm( ADsort 'browse 'srcLib )"
    ) 20:60 260:025 80 )
    ?name 'Srcsort
    ?buttonText "Sort by date"
    ?enabled t
    ?callback some Awk program that run sortingl"
    ) 20:90 260:025 80 )
    but I keep  getting error  :
     *Error* eval: undefined function - sort_by_date
    <<< Stack Trace >>>
    sort_by_date("sortutility" "" "" "" "" ... )
    (... in ddsiLMCEval ...)
    (... in ddsLMCMenuItem ...)
    ddsLMCMenuItem(1 "sortutility" "sort_by_date" ("" "" "" "" ""))
    any ideas?
    thx
    meny
    Hi Meny,
    There are two issues:
    1. The code needs to be loaded in two different places. The lmgr calls (the bit at the top of your code) needs to be in cdsLibMgr.il, whereas the two functions sort_by_date and MLsort need to be loaded from the .cdsinit. This is because the menu customization needs to be in the separate library manager process, whereas the callbacks are called in the main virtuoso process.
    2. The sort_by_date callback function needs to be written to expect 6 arguments - see the examples in the documentation (actually written by me from an application note I wrote on this back in IC441/IC442 timeframe!)
    Here's the modified sort_by_date function - if I did the separation of the code as above, and modified the function this way, it brings up the form and seeds the library based on the selected library:
    procedure( sort_by_date(menuName lib cell view file category)
      MLsort()
      printf("yes\n")
      unless(blankstrp(lib)
        ADsort->srcLib->value=lib
  • ivick
    ivick over 6 years ago
    It seems that ddsGetLibManLCV() could be an option.
    Ivick.
    Andrew Beckett over 6 years ago in reply to ivick
    It's still not intended as a browser though (as I said in my original reply), so building tools that use whatever is currently selected in the library manager to inform what you're doing would be a use model different to everything else in Virtuoso. You should use the library browser (by using fields on the form, a browse button and linking them with ddsSyncWithForm)
