  3. Problem running remote simulation in ADE
  • Replies 10
  • Subscribers 133
  • Views 20315
nicolasbara
nicolasbara over 14 years ago
Hi
I am having the following problem while trying to run a remote simulation in ADE using IC 5.1:
In ADE window I go to Setup ->  Simulator/Directory/Host, select remote, then enter Host, Project Directory and Remote Directory
When I press OK I get the following WARNING:
 *WARNING* - Virtuoso® Analog Design Environment: Local directory /iie/home01/barabino/simulation and remote directory /iie/home01/barabino/simulation on host yerbal do not appear to be the same
In fact they are the same because the same network disk is mounted on both hosts
Also, although it is a WARNING it acts like an ERROR because it does not allow me to continue with the setup
I am running icfb.exe version 5.1.0 07/26/2009 22:40 (cicln04)
I appreciate any help
Regards
Nicolas
  • nicolasbara
    Another question: Why is it that I find so litle information about this on the web? Is there another way of simulating on a remote host using ADE?
  • Quek
    Quek over 13 years ago
    Hi Nicolas
    It is possible that you are facing a bug issue reported in our R&D request CCR644971. A possible workaround is to set the following environment variable:
    envSetVal("asimenv.startup" "remoteTimeOut" 'int 100)
    You can get more help from Cadence online support website.
    Best regards
    Quek
    The other possibility is that "rsh" is not supported in your environment (maybe you have to use ssh?), or that "rsh" requires a password?
    In IC5141, only "rsh" is supported - the workaround is to replace rsh with a link to ssh.
    Best thing is to contact customer support at http://support.cadence.com
  • nicolasbara
    nicolasbara over 13 years ago
    Hi Thank you Andrew and Quek for your answers. Adding that line to .cdsenv solved the problem. Now I can run the simulation, however it hangs with: "Entering remote command mode using MPSC service (spectre, ipi, v0.0, spectre1_7543_5, )." Any ideas? Best Nicolas
  • Quek
    Hi Nicolas
    I seem to recall the using the following option can resolve the new problem:
    spectre.envOpts controlMode string "batch"
    Best regards
    Quek
  • nicolasbara
    I tryed with this line envSetVal("spectre.envOpts" "controlMode" 'string "batch") but didn't work, it stills hangs ups.
    Did you set that before you started ADE? It won't work if ADE is already running...
  • nicolasbara
    Great!, now it works. However I have to enter manually that line, it seems not to recognize it on .cdsenv, why is it that? Best regards Nicolas
    In .cdsenv the syntax is:
    Or you can put it in the .cdsinit with the envSetVal() syntax.
  • nicolasbara
    Ok, so it's solved.
    Thank you for your help.
    Best,
    Nicolas
