  3. Symbolics and Translation to IC61
  • Subscribers 132
  • Views 16227
armthy
armthy over 13 years ago
I have noticed that during IC51 to IC61 translation, some of the symbolic/symbolic arrays are unbound in IC61.
On further investigation, I have realized that this is due to incorrect usage of symbolics in IC51.  Instead of using Create->Contact the Symbolics have been added as an Instance. Since I have seen legacy designs that have this usage all over the hierarchy, I am wondering if any forum members has a template of skill code that can go thru a layout hierarchy and replace symbolic instances with the equivalent contacts.
I can run such a code in IC51, correct the layout hierarchy and then run the translation to IC61.
Appreciate any help on this.
Thanks!
  • armthy
     On a related note. Has any of you faced this issue and if so how have you gotten around it?
    If I query the symbolic instance which parameter should tell me that it is a symbolic placed as an instance? To do a replace this is key as I need to differentiate from other instances. Any ideas?
    Thanks!
     I'd be surprised if this was to do with it being placed as an instance in IC5141, since there's not really a difference between an instance and a via in IC5141 - it's the same object in the database.
    Probably best to contact customer support. Then we can take a look at your data and figure out what's going wrong.
  • armthy
     Thanks for your reply. If you place a instance array of a via in IC51 the objType is mosaicInst. This will not translate correctly to IC61. It will be unbound. If you use the "Create->Contact" and create a contact array, this will get translated correctly to IC61 as the vias will be now mapped to the one coming from the techfile via definition.
    Normal 0 false false false EN-US X-NONE X-NONE /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} I was able to create code for this purpose as follows.
    if((cvt~>viewName == "symbolic" && cvt~>objType == "mosaicInst" && cvt~>w) then
                    coordT=(xCoord(lowerLeft(cvt~>mosaic~>bBox))+xCoord(upperRight(cvt~>mosaic~>bBox)))/2.0:(yCoord(lowerLeft(cvt~>mosaic~>bBox))+yCoord(upperRight(cvt~>mosaic~>bBox)))/2.0
                    leCreateContact(cvID cvt~>cellName coordT car(cvt~>mosaic~>tileArray) cvt~>w cvt~>l cvt~>mosaic~>rows cvt~>mosaic~>columns cvt~>mosaic~>uX cvt~>mosaic~>uY  "center" "center")
                    dbDeleteObject(cvt~>mosaic)
                    ) ;if
    OK, that makes sense. I was assuming the symbolic had been placed in IC5141 with the right parameters for rows and columns, rather than being placed as a mosaic.
