  3. What's the equation behind spectrumMeas() function in Viva...
  • Subscribers 132
  • Views 1947
What's the equation behind spectrumMeas() function in Viva calculator?
greatqs
greatqs over 13 years ago
I'm using spectrumMeas() function inside Viva calculator for evaluating THD, THD+N performance of Class-D amplifier outputs.
I saw different measured results coming out of different windowing used and the help information of the function doesn't tell any more detailed equations behind it.
I want to know how the function deal with windowing function. for example, how it deal with additional bins caused by the windowing and how to apply scaling on signal, noise and harmonic bins.
QS
  • greatqs
    Is anyone familiar with the function could help? Thanks!
    Personally I don't have time at the moment to research this, so I would suggest if you want an answer quickly, you should contact customer support.
