  3. Virtuoso layout XL - assign connectivity to the flattened...
  • Subscribers 132
  • Views 4742
Virtuoso layout XL - assign connectivity to the flattened instance
Roopak25
Roopak25 over 13 years ago
Hi
In Virtuoso layout XL, I called all the instances from the schematic. So It was aware of the connectivity. Now i flattened one of the instance to modify it and it lost the connectivity info
So the issue is how to again assign connectivity to the flattened instance
Roopk
    Roopk,
    Which version of the tools are you using? (Help->About in the CIW will tell you the subversion).
  • Roopak25
    Hello andrew
    IC 6.1.5
    Roopak
    Roopak,
    You can use Launch->Configure Physical Hierarchy to tell it how the hierarchy should be expanded, and you can use Connectivity->Define Device Correspondence. In general this isn't necessary as the device binding will get done automatically as you hook up the devices - provided they are unambiguously connected.
  • Roopak25
    Hello Andrew,
    I tried to use define device correspondence but was unsuccessful. I did not understand how to use Configure physical Hierarcy.
    I am unable to bind(conectivity info so that i can get flight lines) the flattened device(nmos) in layout to the device(nmos) in schematic ? Can u please expain in detail ?
    Thanks and regards,
    Roopak
    Hi Roopak,
    Are you saying that you've flattened one of the transistors? I may have misinterpreted what  you were saying and assumed that you'd flattened a hierarchical block.
    What I'd do is to flatten (preserving pins) and then use Make Cell to create a new cell for the modified transistor - then you can use the Define Device Correpondence to map it.
