  3. ADE-XL is not picking up custom functions
  • Subscribers 132
  • Views 15332
Arshie
Arshie over 13 years ago
Hi
I have written a skill function for calculating SFDR from DFT data. It works perfectly from ADE-L. For some reason ADE-XL has stopped recognising custom functions. The function works from calculator (in ADE-XL mode) and console (in ADE-XL mode). But not from ADE-XL expression evaluator which is supposed to do the final calculations at the end of the simulation. It complains "Undefined Function"
Usage Example: af_sfdr(dB20(dft(VT("/vout_diff") 2.5e-06 1.25e-05 256 "Rectangular" 1 "default")))
procedure(afVecMax(vec)
len = drVectorLength(vec)
valMax = -1e10
index = nil
for(pos 0 sub1(len)
when((valMax < drGetElem(vec pos))
index = pos
valMax = drGetElem(vec pos)
valMax
procedure(afFindInVector(vec val)
valInVec = -1e10
index = nil;
for(pos 0 sub1(len)
valInVec = drGetElem(vec pos)
if((valInVec == val) index = pos)
index
procedure(afExtractFirstWaveFromFamily(fin)
fValues = listToVector(famGetSweepValues(fin))
firstValue = fValues[0]
famValue(fin firstValue)
procedure(afSFDR_onWave(myfft)
yvec = drGetWaveformYVec(myfft)
len = drVectorLength(yvec)
newY = drCreateVec('double len)
for(pos 0 sub1(len)
drAddElem(newY drGetElem(yvec pos))
index = afFindInVector(yvec afVecMax(yvec))
drSetElem(newY index -1.0e3)
xvec = drGetWaveformXVec(myfft)
myfft2 = drCreateWaveform(xvec newY)
ymax(myfft)-ymax(myfft2)
procedure(af_sfdr(fftin)
cond(
(drIsWaveform(fftin) afSFDR_onWave(fftin))
(famIsFamily(fftin) famMap('afSFDR_onWave fftin))
;(famIsFamily(fftin) famMap('afSFDR_onWave fftin))
;(famIsFamily(fftin) afSFDR_onWave(afExtractFirstWaveFromFamily(fftin)))
procedure(af_sfdr_callback()
calSpecialFunctionInput('af_sfdr nil)
calRegisterSpecialFunction(list("af_sfdr" 'af_sfdr_callback))
  • sunilm
    sunilm over 13 years ago
    Hi Arshie,
    Try loading it from .cdsinit instead of loading directly in your existing session.
    Sunil
  • Arshie
    Spot on! Now it works!
    Arshad
