  3. problem through simulation of LDI(lossless discrete integrator...
  • Subscribers 132
  • Views 1494
problem through simulation of LDI(lossless discrete integrator) resonator using spectre
Farnam
Farnam over 13 years ago
hi
i have simulated LDI resonator using spectre , in the right case and other simulator like lt-spice my output oscilate with my resonance frequency in the form of a pulse shape waveform ( like clock generator ) . but in the cadence my waveform is like following picture ( attachment file here ) i dont know what to do ?? because my circuit and everythings are correct but the waveform not !and my second problem is that , my waveform  eventually converge to the zero ! why ????? if i increase the gain of my micro model opamp i 've just increase the time of convergance , but again eventually it will be converge to the zero (as follow pictures )
if any body can help me, i will be grateful
best regards
picture :    http://www.4shared.com/photo/xHtCaRxy/errd.html
    Not much info to go on here, but first step - make sure that you have method=traponly specified in your transient.
  • Farnam
    thanks andrew , i will try it ! i hope it works
     Farnam
  • Farnam
    hi dear andrew , i 've changed my integration method to traponly and finally it has worked ! thank u very much
    best regards
