  3. $bitstoreal function in IC6.1.5 systemVerilog
  • Subscribers 131
  • Views 16800
archive over 13 years ago
Hi All,
I am having the following weird issue:
I am trying to do some AMS simulation using IC6.1.5 and ADE.
I created a systemVerlog view and used the function "$bitstoreal". When I try to save and close the editor, I get an error: "ncvlog: *E,NOTCMP: unit bitstoreal not found while parsing."
But the error is not present when I try to use "$realtobits". As far as I could gather from the resources, I could see both the functions can be used in systemVerilog and should not be an issue.
Any suggestions to fix this issue is welcome. Thanks a lot in advance!
BR,
Vijay
    Sorry for the trouble. It was some cadence issue, after restarting it got fixed!
