  3. Cannot pass parameters from virtuoso sch. into Verilog ...
  • Replies 13
  • Views 27765
Cannot pass parameters from virtuoso sch. into Verilog module
Pavel47
Pavel47 over 14 years ago
 I've met problem while passing parameter value, specified on the schematic.
Here is Verilog module:
module Pixel_v0 (input Din, CLK, output Dout );
   parameter SEED = 33;
   integer INTSEED=SEED;
   reg [15:0] DATA;
   assign Dout = DATA[15];
//   initial DATA = $random(INTSEED);
   initial DATA = INTSEED;
   generate
      genvar  i;
      for (i = 0; i < 15; i=i+1) begin: DFF
     if (i==0)
       always @(posedge CLK)
         DATA[i] <= Din;
       DATA[i+1] <= DATA[i];
      end
   endgenerate
endmodule
On the picture on attachment I shoved concrned instance (with parameter value = 15) and signal waveform. As you can constate, the initial DATA value is 33 (as spicified inside of verilog module), but not 15 (as sppecified in schematic).
Where is a problem.
Thanks in advance.
Pavel.
  • Pavel47
     Andrew,
    Unfortunately the changes aren't kept. So, each time after launching Cadence I have to repeate the procedure.
    Is there some workaround ?
    Thanks.
    Pavel.
     Pavel,
    Did you remember to change the CDF type to "Base" (rather than "Effective")? Otherwise it will be done in memory only.
  • Pavel47
    Pavel47 over 13 years ago
    Andrew,
    I didn't touch my Cadence project since some weeks due to other more urgent job. Surprisingly when I came back today, I discovered that concerned feature doesn't work ! As one can constate from attached image, the value specified in schematic isn't taken in account, but default (specified in verilog module) instead. Where is a problem ? From accompagnied windowsit seems thatsettings are correct.
    Thanks in advance.
    Pavel.
