  3. Changing the location of job log file
  • Subscribers 131
  • Views 17480
MaK78
MaK78 over 13 years ago
How can I change the location of Job log files (Jobxx.log)? Currently it is stored in ./logs_username.
I am using IC6.1.5-64b.500.9.
Mahmood
    Mahmood,
    I believe it's always logs_username - although in later versions (ISR10 onwards, I think) there's some support in there to make sure that the log files don't clash if you're running two virtuoso sessions as the same user in the same directory.
    If you need it changed for some reason, please log a service request.
