  3. Stream in warning
  • Subscribers 132
  • Views 14985
Stream in warning
ARYAMVALLI
ARYAMVALLI over 13 years ago
 I have a SRAM memory instance which is generated using a compiler. while streaming it in I am getting the following warning
"WARNING (XSTRM-80037): A zero-area polygon was encountered and ignored." for a particular leaf cell in the design.Can anyone tell me why is this happening and a solution to fix this problem.
Regards
Vipin
    Vipin,
    Presumably you have a zero-area polygon in the stream file? Isn't the message pretty explicit?
  • ARYAMVALLI
    Thanks for ur feedback.
    There were no problem in the layout.But there was some naming conflict in the tiler and that created this junk error.
    Regards
    Vipin
