  3. Translating IC6 libaries to IC5
  • Replies 8
  • Subscribers 133
  • Views 18959
gparasiliti
gparasiliti over 13 years ago
Is there a way to downgrade an IC6 library to IC5? I know it's strange buit in some case it should be the best way to reuse some IP.
Giuseppe
    Hi Giuseppe,
    oa2cdb is what you want.
  • gparasiliti
    Thanks for your reply, but when I try to use it I have the below error:
      ERROR   (OACDB-113): Failed to find the OpenAccess library "TEST_CONVERSIO"
     I checked the cds.lib definition and it seems ok.
     Giuseppe
    Giuseppe,
    I believe oa2cdb requires a lib.def file not a cds.lib file. So here's what I did to make this work:
    # starting in my existing directory that contains OA libraries
    mkdir CDB
    cdsLibEditor -batchWriteLibdefs lib.defs
    cd CDB
    oa2cdb -cdslibpath ../lib.defs -lib mylib
    The cdsLibEditor has a batch mode to convert a cds.lib into the standard OA lib.defs format (similar to cds.lib, but only supports a subset of the syntax).
  • gparasiliti
    The problems was related to lib.defs file as you wrote, I fixed it but now after the conversion I have some problem with the pin name:
      ERROR   (OACDB-638): Cannot translate pin "68" for terminal "EN" in cellview
                         'TEST_CONVERSIO "CELLNAME" schematic' because the CDB
                         master cellview 'basic ipin symbol_xform' is not available.
                         Ensure that the library containing the master is correctly
                         defined in the CDB cds.lib file. If the master is not yet
                         available in CDB, translate it from OpenAccess to CDB first
                         and then rerun the translator for the remaining cells in
                         the library.
    Do you have any suggestion?
     Giuseppe
  • dmay
    dmay over 13 years ago
    The _xform views do not convert backward very well. Technically, OA doesn't support magnification of instances. Howerver cdb2oa would create pcell versions of symbols that have a magnification parameter so that magnified instances will show up in OA. This is essentially a hack by Cadence to work around the limitation provided by Open Access. Your best bet is to not magnify anything, then you won't have any symbol_xform views in OA.
    To solve your problem, you can search for the symbol_xform instances and replace them with symbol views instead. Then set the magnification property on the new instance (if necessary). The oa2cdb won't do this for you automatically. Basically, I've found the more I deal with the xform solution, the more I want to eliminate any magnification at all in our designs.
    Derek
  • gparasiliti
     I don't know how I can search the viewname... sorry but I'm switching only now in IC6.
     Reagrds,
    Giuseppe
  • gparasiliti
    I checked again and my problem is about pin name with view name "symbol". It seems the procedure can not covert the pin name correctly.
     ERROR   (OACDB-638): Cannot translate pin "P__2" for terminal "V" in cellview
                         'TEST_CONVERSIO "CELLNAME" schematic' because the CDB master
                         cellview 'basic ipin symbol' is not available. Ensure that
                         the library containing the master is correctly defined in
                         the CDB cds.lib file. If the master is not yet available in
                         CDB, translate it from OpenAccess to CDB first and then
                         rerun the translator for the remaining cells in the
                         library.
     Giuseppe
     Giuseppe,
     Make sure that in the destination directory your cds.lib has any required reference libraries (e.g. basic) defined (sorry, I didn't explain that earlier) - so you'll need basic, analogLib, and any PDK libraries also defined. Actually the message makes that quite clear...
