  3. monte carlo trimmed simulation in adexl (cadence 6)
  • Subscribers 133
  • Views 18018
Trevor1981
Trevor1981 over 13 years ago
Does anyone know how to setup monte carlo simulation under adexl in such way that:
- 1st test bench uses tran smulation to find a trimming code for a particular instance (DUT)
- 2nd test bench uses dc temp sweep to run a monte carlo trimmed simulation
Problem: In both test benches DUT should contain devices with the same mismatch spread on their model parameters. It seems that my DUT has different monte carlo spread in both test benches and the trimming doesn't really have any effect.
Thanks for your help.
  • Frank Wiedmann
    Frank Wiedmann over 13 years ago
    Cadence has just published a very detailed application note on this subject (dated August 8, 2012). It's called "Calibrated Verification with ADE XL" and it can be found at http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:doc;src=wp;q=ApplicationNotes/Custom_IC_Design/appNote_Calibrated_Verification.pdf .
  • Trevor1981
    Thanks Frank. That's the information I was looking for.
    Best regards,
