  3. How to compile verilog file to valid IC6.x cellview from...
  • Subscribers 132
  • Views 15492
How to compile verilog file to valid IC6.x cellview from command prompt
aleksand1975
aleksand1975 over 13 years ago
I need to compile verilog files to valid  IC6.x cellviews from command prompt (batch file).
In IC5.x I used command “ncvlog –use5x...” to compile existing verilog file to valid cellview
In  IC6.x with ncvlog 11.1 cellview still criated in format of IC5.x . It meens no netlist.oa and some other files that exists in IC6.x cellview.
So can you please explain me how can i create valid  IC6.x cellview using command prompt command?
THank you very much.
     In IC5141 it didn't create the ".cdb" file either. You can compile the files in using ncvlog -use5x still, but to create the "shadow" databases (which contain the info about terminals and so on needed for OSS netlisting), you should use the vmsUpdateCellViews() SKILL function. Search in cdnshelp for this function for details as to how it should be used.
  • aleksand1975
    Hi Andrew,
    Thank you for explanation. But is it a way to run this function (vmsUpdateCellViews()) from batch file?
    Alex.
