  3. Fasten the startup time of simulation?
  • Subscribers 133
  • Views 16493
Rune
Rune over 13 years ago
I am trying to simulate a rather large circuit with extracted parasitics. I am running IC5.1.41 with MMSIM11. From when I push "Netlist and run" the time to start the simulation can take hours, while the simulation (i.e. from when spectre is instantiated) itself is like 30 minutes. Is there a way to make this initiation become faster?
  • Quek
    Quek over 13 years ago
    Hi Rune
    You can speed up your simulation using any one of the following methods:
    a. If you are using QRC, do RC-reduction during QRC
    b. Use spectre aps mode
    c. Use spectre rc reduction
    Best regards
    Quek
  • Rune
    Yes, I am aware of those. But the problem is related to virtuoso, this is prior to spectre is instantiated (spectre process is not running at this moment only virtuoso).
    This is quite likely a bug that's been fixed in IC61X, but if it's what I think it is, please open the extracted view in a window prior to opening ADE. The issue was that at various points ADE was opening and closing the extracted view (when processing the outputs, and during netlisting) - and because the extracted view was not open elsewhere it was flushing it from memory and re-reading from disk each time. Opening in a window prevents it from flushing from memory.
