  3. "'redefinedparams' is not a valid parameter for an instance...
  • Subscribers 132
  • Views 5810
"'redefinedparams' is not a valid parameter for an instance of 'options'. Ignored."
JustinTaylor86
JustinTaylor86 over 13 years ago
 In my .scs file I want to redefine previously defined parameter
 redefinedparams worked in Cadence 5 but does not work for me in Cadence 6.
Does anyone know what the new syntax is?
  • Ashish Patni
    Ashish Patni over 13 years ago
    Hi Justin,
     I am not entirely sure what is happening here, however, you can have a look at the following Solution and see if this helps -
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11329058
    With Regards,
    Ashish
    You must be using a version of spectre that is too old - a bit odd that you're using an older version with IC6 than with IC5, but it is presumably something in your environment.
