  3. Difference between monte carlo simulation and normal ADE...
  • Replies 7
  • Subscribers 133
  • Views 18883
Difference between monte carlo simulation and normal ADE L simulation
RAJ JOHRI
RAJ JOHRI over 13 years ago
Hello!
Can anyone explain me what is difference between monte carlo simulation under ADE XL and a normal simulation under ADE L. I am working on single electron transistor. Number of research papers tell that they have simulated it using monte carlo simulation and the results have been obtained using single electron device simulator known as SIMON.
Please tell me, if I simulate the same single electron transistor model under cadence, would it make any difference or it can't be simulated in cadence.
Thank You!
  • Quek
    Quek over 13 years ago
    1024x768 Normal 0 false false false EN-US JA X-NONE MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
    Hi Raj
    The normal simulation in ADE-L is just a single simulation based on preset parameter values. Monte Carlo simulation in ADE-XL is a series of simulation (e.g. 100 independent simulations) that usually uses random Gaussian values for certain parameters. This is to model the random nature of the changes in parameter values during mass production of a chip.
    I googled "single electron device simulation spectre" and seems to get quite a number of results. E.g.
    http://tinyurl.com/csosyxc
    From the abstract of the following paper, it seems that there should not be a problem in using a spice/spectre mode lto describe the single electron circuit:
    http://www.researchgate.net/publication/27348209_Simulation_of_single-electron_tunnelling_circuits_using_SPICE
    If you have the appropriate models, I think it should be fine. Sorry that I don't have any info on the difference between spectre/SIMON results. If you are having problems with the simulation, perhaps you can re-examine your model or contact your local Cadence support for more help. Hope that this info is useful for you. : )
    Best regards
    Quek
  • RAJ JOHRI
    Thank You Queck, for your response.
    I have the SET model and tried to simulate it using ADEL but I am not getting the response as desired. Now I want to simulate it using monte-carlo simulation as most research papers have done the simulation using the same process, but I don't know how to use monte carlo options which is located in ADE-XL.
    Please help me providing some useful guide to use monte-carlo option for simulation in cadence spectre which explains meaning of every options given in the monte carlo simulation. Or, using a small circuit like inverter please explain me how to simulate it using monte-carlo simulation.
    Please reply me, I am waiting for your response.
    Thank You.
  • Quek
    Hi Raj
    ADE-XL user guide has very clear steps and explanations on how to run Monte Carlo. Would you please look at the user guide?
    a. In your terminal window, go to $CDSHOME/doc/adexl
    ($CDSHOME refers to the IC61 installation path
    b. Execute the following:
    terminal>acroread adexl.pdf &
    By the way, you have spelt my name wrongly.
    Best regards
    Quek
  • RAJ JOHRI
    Thank You Quek. Sorry for incorrect spelling your name.
    I will study the pdf and reply you later.
  • RAJ JOHRI
    Hi Quek!
    I did'nt got the pdf, howerver I got a mannual on the internet that explained the monte carlo simulation.
    But I still did'nt got the response of the single electron transistor. I have the equivalent model with all the parameter values of the components used. I simulated it using monte carlo simulation, but nothing changed. I am still not getting the response of single electron transistor.
    I got that the part of device known as single electron box, which is nothing but a RC circuit, is not giving the desired response at constant voltage, as research paper said. They all have simulated it using spice or SIMON, but I want it to work with cadence as I have this only tool at my institute. If required, I will send you the circuit of single electron box with all parameter values and image of desired response.
    Please help me in this regard. I would be very thankful to you.
  • Quek
    Hi Raj
    Actually the manual is definitely available in your IC61 installation. You can get to it as follows:
    a. In a terminal window, execute the following:
    >which virtuoso
    b. Assuming that the return value is "/my-path/abc/IC615_ver123/tools/dfII/bin/virtuoso", please go to:
    >cd /my-path/abc/IC615-ver123/doc/adexl
    c. Locate the pdf file in the directory
    If you are still unable to find the file, you can view it here on the COS website.
    It is a very interesting question because I have not had any experience in doing single electron simulations but I think it would be better if you send in a complete testcase to your local Cadence support to check if there is anything wrong with your setup. This will be the fastest method to resolve the problem. : )
    Spectre should be able to give the same results as a spice simulator so using spectre should not be an issue.
    Best regards
    Quek
  • RAJ JOHRI
    Thank You So much Quek for your response.
    I am attaching the circuit diagram (it is a reference from a research paper and is not proposed by me) and the desired response of the single electron box which is a basic part of the single electron transistor. The box indicating RT and Cj are resitance and capacitance respectively in parallel.
    Cj = 1aF (atto Farad)
    RT > 26 K Ohm
    R = 1 Mega Ohm.
    Voltage Vb = 0.1 V
    The response is Time vs Vj and Time vs Ij as shown in the expected response.
    I think I am not able to plot the response correctly. If you get the response please tell me the step by step method how to plot the response.
