  3. Problem of QRC with Generic 45nm PDK (gpdk045)
  • Subscribers 133
  • Views 17714
ecesys
ecesys over 13 years ago
When I run the QRC with gpdk45, It was always failed.
Specially, When I used capacitor and inductor models, it happened
It looks like that several library models are missed.
Please see below log file.
Thanks you for your attention.
  Cadence Extraction QRC - Parasitic Extractor - Version 10.1.3-p065 Tue
Oct  4 20:59:14 PDT 2011
                            Copyright 2010 Cadence Design Systems, Inc.
INFO (EXTQRCXOPT-243) : For Assura inputs, if the "output_setup -directory_name" option was not
specified, it is automatically set to the input directory.
INFO (LBRCXU-108): Starting
 /tools/cadence/ASSURA41/tools/assura/bin/rcxToDfII /home/centos/test045/lvs/inv/__qrc.rcx_cmd -t -f /home/centos/test045/lvs/inv/extview.tmp -w /home/centos/test045/lvs/inv -cdslib /home/centos/test045/cds.lib
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.24s.
@(#)$CDS: rcxToDfII version av4.1:Production:dfII6.1.5:IC6.1.5.500.9 03/01/2012 03:51 (sfrh329) $
sub-version 4.1_USR2_HF14, integ signature 2012-03-01-0259
run on centos from /tools/cadence/ASSURA41/tools.lnx86/assura/bin/32bit/rcxToDfII on Thu Aug 23 23:31:24 2012
Loading tech rule set file : /home/centos/PDKs/gpdk045_v_3_5/assura/techRuleSets
Loading gpdk045/libInit.il ...
Loading gpdk045/loadCxt.ile ... done!
Loading context 'gpdk045' from library 'gpdk045' ... done!
Loading context 'pdkUtils' from library 'gpdk045' ... done!
Loading gpdk045/gpdk045_customFilter.il ... done!
Loading gpdk045/libInitCustomExit.il ...
Loading Environment Settings ...
Loading gpdk045/gpdk045_PDKRegistrations.il ... done!
  *              Cadence Design Systems, Inc.                 *
  *                    Generic 45nm PDK                       *
  *                        (gpdk045)                          *
VERSION: 3.5
done!
Loaded gpdk045/libInit.il successfully!
*WARNING* No library model for device "g45inda".
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (g45cmim ivpcell) from lib (gpdk045) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
*WARNING* No library model for device "g45cmim ivpcell gpdk045".
*WARNING* No library model for device "g45inds".
INFO (LBRCXU-114): Finished /tools/cadence/ASSURA41/tools/assura/bin/rcxToDfII
 /tools/cadence/ASSURA41/tools/assura/bin/avRCXxref /home/centos/test045/lvs/inv/__qrc.rcx_cmd -useRunName
@(#)$CDS: avRCXxref version av4.1:Production:dfII6.1.5:IC6.1.5.500.9 03/01/2012 03:48 (sfrh329) $
run on centos at Thu Aug 23 23:31:24 2012
Reading rsf
INFO (LBRCXU-114): Finished /tools/cadence/ASSURA41/tools/assura/bin/avRCXxref
INFO (LBRCXM-642): Constructing the RCX run script
INFO (LBMISC-215205):
*** Cadence Extraction QRC Techgen -trans VERSION 10.1 Linux 32 bit - (Tue Oct  4 19:48:09 PDT 2011)  ***
INFO (CAPGEN-41199):
Techgen -trans results will be written to directory: /home/centos/test045/lvs/inv
Forking:  /tools/cadence/EXT101/tools.lnx86/extraction/bin/32bit//capgen -techdir /home/centos/PDKs/gpdk045_v_3_5/qrc/typical -lvs /home/centos/test045/lvs/inv.xcn -p2lvs /home/centos/PDKs/gpdk045_v_3_5/qrc/typical/qrcTechFile -reseqn -p poly_conn,allGate,Oxide -canonical_res_caps -length_units meters -exclude_gate_res -cap_ground_layer psubstrate /home/centos/test045/lvs/inv
Successfully created RCX script '/home/centos/test045/lvs/inv/rcx.sh'
INFO (LBRCXM-581): Checked out '1' license(s) for Virtuoso_QRC_Extraction_XL 10.10
INFO (LBRCXM-608): Executing command
   /bin/ksh  /home/centos/test045/lvs/inv/rcx.sh
##ADD_EXPLICIT_VIAS=N
##ADD_BULK_TERMINAL=N
##AGDS_FILE=/dev/null
##AGDS_LAYER_MAP_FILE=/dev/null
##HCCI_DEV_PROP_FILE=/dev/null
##AGDS_SPICE_FILE=/dev/null
##AGDS_TEXT_LAYERS=
##ARRAY_VIAS_SPACING=
##ASSURA_RUN_DIR=/home/centos/test045/lvs
##ASSURA_RUN_NAME=inv
##BLACK_BOX_CELLS=/dev/null
##BREAK_WIDTH=
##CAP_COUPLING_FACTOR=1.0
##CAP_EXTRACT_MODE=coupled
##CAP_GROUND=gnd
##CAP_MODELS=no
##DANGLINGR=N
##DEVICE_FINGER_DELIMITER='@'
##DF2=Y
##DRACULA_RUN_DIR=
##DRACULA_RUN_NAME=
##ENABLESENSITIVITYEXTRACTION=N
##EXCLUDE_FLOAT_LIMIT=
##EXCLUDE_FLOAT_DECOPULING_FACTOR=
##EXCLUDE_FLOATING_NETS=N
##EXCLUDE_NETS_REDUCERC=/dev/null
##EXCLUDE_SELF_CAPS=N
##IGNORE_GATE_DIFFUSION_FRINGING_CAP=Y
##EXTRACT=cap
##EXTRACT_MOS_DIFFUSION_AP=N
##EXTRACT_MOS_DIFFUSION_HIGH=
##EXTRACT_MOS_DIFFUSION_RES=N
##FILTER_SIZE=2.0
##FIXED_NETS_FILE=/dev/null
##FMAX=
##FRACTURE_LENGTH_UNITS=microns
##FREQUENCY_FILE=/dev/null
##GROUND_NETS=
##GROUND_NETS_FILE=/dev/null
##HCCI_DEV_PROP=7
##HCCI_INST_PROP=6
##HCCI_NET_PROP=5
##HCCI_RULE_FILE=
##HCCI_RUN_DIR=
##HCCI_RUN_NAME=
##HEADER_FILE=/dev/null
##HIERARCHY_DELIMITER='/'
##HRCX_CELLS_FILE=/dev/null
##IMPORT_GLOBALS=Y
##LADDER_NETWORK=N
##LVS_SOURCE=assura
##M_FACTORR=
##M_FACTORW=N
##MACRO_CELL=Y
##MAX_FRACTURE_LENGTH=infinite
##MAX_SIGNALS=
##MERGE_PARALLEL_R=N
##MINC=1e-17
##MINC_BY_PERCENTAGE=1
##MINR=0.001
##NET_NAME_SPACE=schematic
##NETS_FILE=/dev/null
##OUTPUT=/home/centos/test045/lvs/inv/extview.tmp
##OUTPUT_NET_NAME_SPACE=layout
##PARASITIC_BLOCKING_DEVICE_CELLS_TYPEgray
##PARASITIC_CAP_MODELS=no
##PARASITIC_RES_MODELS=comment
##PARASITIC_RES_LENGTH=N
##PARASITIC_RES_WIDTH=N
##PARASITIC_RES_WIDTH_DRAWN=N
##PARASITIC_RES_UNIT=N
##PARTIAL_CAP_BLOCKING=N
##PEEC=N
##PIN_ORDER_FILE=/dev/null
##PIPE_ADVGEN=
##PIPE_SPICE2DB=
##POWER_NETS=
##POWER_NETS_FILE=/dev/null
##RC_FREQUENCY=
##RCXDIR=/home/centos/test045/lvs/inv
##RCXFS_HIGH=N
##RCXFS_NETS_FILE=/dev/null
##RCXFS_TYPE=none
##RCXFS_CUTOFF_DISTANCE=
##RCXFS_VIA_OFF=N
##REDUCERC=N
##REGION_LIMIT=
##RES_MODELS=no
##RISE_TIME=
##SAVE_FILL_SHAPES=N
##SINGLE_CAP_EDSPF=N
##SHOW_DIODES=N
##SKIN_FREQUENCY=
##SPEF=N
##SPEF_UNITS=
##SPLIT_PINS=N
##SPLIT_PINS_DISTANCE=
##SUB_NODE_CHAR='#'
##SUBSTRATE_PROFILE=/dev/null
##SUBSTRATE_STAMPING_OFF=N
##TEMPDIR=/home/centos/test045/lvs/inv/rcx_temp
##TYPE=full
##USER_REGION=/dev/null
##VARIANT_CELL_FILE=/dev/null
##VIA_EFFECT_OFF=N
##VIRTUAL_FILL=
##XREF=/home/centos/test045/lvs/inv/inv.gnx,/home/centos/test045/lvs/inv/inv.gdx
##XY_COORDINATES=c,r
CASE_SENSITIVE=TRUE
export CASE_SENSITIVE
TEMPDIR=`setTempDir /home/centos/test045/lvs/inv/rcx_temp`
setTempDir /home/centos/test045/lvs/inv/rcx_tempexport TEMPDIR
cd /home/centos/test045/lvs/inv
cat <<ENDCAT> caps2dversion
* caps2d version: 10
ENDCAT
cat <<ENDCAT> flattransUnit.info
meters
ENDCAT
QRC=Y
export QRC
cat <<ENDCAT> topcellxcn.info
ENDCAT
# Generate RCX input data from Assura LVS database
GOALIE2DIR=/tools/cadence/EXT101/tools.lnx86/extraction/bin
export GOALIE2DIR
vdbToRcx /home/centos/test045/lvs inv -unit meters -- -V1 -H satfile -r \
/home/centos/test045/lvs/inv.xcn -df2 -xgl
@(#)$CDS: vdbToRcx version av4.1:Production:dfII6.1.5:IC6.1.5.500.9 03/01/2012 03:51 (sfrh329) $
9.1 Linux 32 bit - (Tue Aug 10 20:34:40 PDT 2010)
Opening LVS data for inv in /home/centos/test045/lvs
Open time is 0.0 sec.
Build pins/attributes took 0.0 sec.
Processing metal1_conn_pintext                   2 shapes 0.0 sec.
create satfile took  0.01 user, 0.00 sys, 0.00 elapsed, 146408.0 kbytes
write edge metal1_conn_pintext took  0.00 user, 0.00 sys, 0.00 elapsed, 146408.0 kbytes
Building net map file. 0.0 sec.
create netmap file took 0.00 user, 0.00 sys, 0.00 elapsed, 146408.0 kbytes
create net file took 0.00 user, 0.00 sys, 0.00 elapsed, 146408.0 kbytes
WARNING (LBCLV-5663): No bipolar models provided. Can't create bipolar files
WARNING (LBCLV-5660): No resistor models provided. Can't create resistor files
WARNING (LBCLV-5657): No diode models provided. Can't create diode files
WARNING (LBCLV-5706): no generic models in rule file
Device creation took 0.0 sec
Processing Via1                                  5 shapes 0.0 sec.
write edge Via1 took  0.00 user, 0.01 sys, 0.00 elapsed, 147296.0 kbytes
Processing Via2                                  5 shapes 0.0 sec.
write edge Via2 took  0.00 user, 0.00 sys, 0.00 elapsed, 147488.0 kbytes
Processing Via3                                  5 shapes 0.0 sec.
write edge Via3 took  0.00 user, 0.00 sys, 0.00 elapsed, 147680.0 kbytes
File vrxsat.c, Line 41, Function noname *FATAL* Illegal to create net avS0 in(inv layout test)
Processing via10_nocap                    vdbToRcx:voiFatal+286()
vdbToRcx:vrxGetNetId+272()
vdbToRcx:vrxWriteEdgeFiles+923()
vdbToRcx:vrxMain+993()
vdbToRcx:main+27()
Abnormal termination at Thu Aug 23 23:31:25 2012
intermediate:   0.05dt 0dw 0.07t 144.4meg 1pf 0.0rss 1081820672r 0w
errno: 0, code: -6
*ERROR* Abort - run abnormally terminated
ERROR (LBRCXM-609): Bad return status from RCX run. 0x100
INFO (LBRCXM-709): *****  QRC terminated abnormally  *****
  • Quek
    Quek over 13 years ago
    Hi ecesys
    This is due to wrong connectivity in Assura lvs extract.rul file. Some connectivity cmds must have been accidentally overwritten. I can reproduce the problem using "inda" cell from gpdk045_ver4.6. The problem can be bypassed if we turned on the centreTap inductor switch during LVS but this results in another mismatch terminal between device/symbol for inds cell.
    Would you please report the issue to your local Cadence support so that we can fix it?
    Quek
