  3. Skill code for extracting wire information for one sign...
  • Subscribers 132
  • Views 15864
Skill code for extracting wire information for one signal
MYIN
MYIN over 13 years ago
 Is there any skill code available to extract wire information from layout for singal signal?
Ming
  • skillUser
    skillUser over 13 years ago
    Hi Ming,
    There may be - but your question is unspecific and you did not mention which version you are using. What do you mean by "wire" do you mean physical characteristics of a segment or segments on a specific net, or do you mean logical information about the net/signal ?
    More detail of what you are looking for will get you a better answer.
    regards,
    Lawrence.
  • MYIN
     What I meant is the geometry information, such as wire length, width, spacing for different segments of a specific net.
    version is 6.1.5
  • skillUser
    Hi Ming,
    The net could be selected in the Navigator, then you could use hsmGetSelectedSet() to obtain the net name and work from that point.
    So let's assume my net of interest is net51...
    cv = geGetEditCellView()
    => db:0x16ab5e92
    netId = dbFindNetByName(cv "net51")
    =>db:0x16ab469c
    pathsOrSegs= setof(obj netId~>figs member(obj~>objType list("pathSeg" "path")))
    => (db:0x1d075e27 db:0x1d075e28 db:0x1d075e26 db:0x1d075e25 db:0x1d075e20
    foreach(object pathsOrSegs
      when(object~>objType=="pathSeg"
      printf("W=%g L=%g\n"
        object~>width
        abs(car(setof(val rodSubPoints(object~>beginPt object~>endPt) abs(val)>0.0)))
      ); when it is a pathSeg
    ); foreach
    ;; prints the following:
      W=0.06 L=0.885
      W=0.06 L=0.54
      W=0.06 L=0.48
      W=0.08 L=0.54
      W=0.06 L=0.13
    A path would need to be treated differently to a pathSeg (because it does not have "beginPt" and "endPt" attributes), but hopefully you get the idea from the above example.  I wrote CCSgetPathLength for paths...
    Hopefully this is close to what you were looking for?
    Lawrence.
