  3. Cannot use $cds_analog_exists or $cgav system tasks.
  • Subscribers 131
  • Views 15970
freitas
freitas over 13 years ago
Hey all,
do I need to use any special option in order to use the cadence system tasks to fetch values associated with analog objects (i.e., $cds_analog_exists() or $cgav() )?  I'm using irun version 11.10-s057.
Here is a trivial example:
File cgav.v
module test;
   wire testv;
   initial
     begin
#0;
if ($cds_analog_exists("testv"))
 begin
    $display("testv belongs to the analog domain");
 end
     end
endmodule
Here how I try to run it:
 > irun  cgav.v
Here is what I get:
*W,MISSYST (./cgav.v,9|22): Unrecognized system task or function (did not match built-in or user-defined names)
*E,MSSYSTF (./cgav.v,9|22): User Defined system task or function registered during elaboration and used within the simulation has not been registered during simulation.
Thanks much!
  • freitas
    I figured the problem! I need the analog kernel to be able to use these functions.
