  3. Modgen member spacing while routing
  • Subscribers 133
  • Views 16791
jkopanski
jkopanski over 13 years ago
 I am trying to tech myself propper modgen usage. As of now I was able to place rather large current mirror, add dummy devices to it and route it properly.
However when I apply routing modgen losses vertical spacing between members, makeing it non uniformly space.
Is there a way to make it keep vertical spaceing, or make it spread rows uniformly?
  • Quek
    Quek over 13 years ago
    Hi jkopanski
    As this problem might be testcase dependent, would it be possible for you to contact your local Cadence to resolve it? If it is not possible, would you please upload a snapshot of the modgen display?
    Quek
  • jkopanski
    Thanks for interest in my problem.
    I've contacted local contact as you suggested.
    Here is my modgen before and after routing. Custom space is large eanough to contain even widest routing.
  • jkopanski
    seems like i can only attach 1 file per post. Here is modgen with routing applied.
