  3. Select all rods in the layout
  • Subscribers 133
  • Views 15773
marcop
marcop over 13 years ago
 Hi all,
I'm a beginner of using ROD object and in the layout I need to select all shapes that have rodName!=nil. For example, if there are 20 active rects but only 5 are defined as ROD, I would like to obtain a list with 5 rod elements.
I know that with rodGetObj it is possible to select a ROD, but the problem is that I don't know the rod name.
Moreover, from rod object there is the link to shape (rod~>dbId). Is there also the opposite (that is shape~>rodId)?
Thanks and regards,
Marco
  • dmay
    dmay over 13 years ago
    Here is one way you can do it:
    rodDbs = setof(x geGetEditCellView()~>shapes rodGetObj(x))
    rods = mapcar('rodGetObj rodDbs)
    rodNames = rods~>name
    Derek
  • skillUser
    skillUser over 13 years ago
    Hi Marco,
    There is a built in function to get the ROD shapes directly, rodGetNamedShapes, here's an example:
      cv = geGetEditCellView()
      rodIds = rodGetNamedShapes(cv)
      ;; if you want to select these shapes, try something like this
      mapcar('geSelectObject rodIds~>dbId)
    As Derek mentioned, you can use the function rodGetObject() to find the rodId from a database object id.
    Lawrence.
