  3. ADEXL -1612 error simulator not in path
  • Views 12118
Ouda
Ouda over 13 years ago
Hello
i got this error when i run simulation using  ADEXL of  IC 6.1.5-64b
"ADEXL -1612 : simulator not in path for the following tests:
Test00
 make sure to have simulator in path for these testsbefore running simulations or disablethese tests "
  • Andre Mansano
    Andre Mansano over 6 years ago in reply to Andrew Beckett +1
    Hello, I want to use the AMS simulator to simulate a system including the VerilogA models and get the same error of ADE-Explorer-1612 error: Simulator no in path. I have tried the mentioned solution…
    Er, isn't the error message pretty clear? It can't find whichever simulator is supposed to be being used for Test00, which means that your UNIX path is not set up correctly.
    I presume you had a question?
  • Ouda
    No it is n't. this test has already spectre in its setting
    can you tell me how to setup this unix path ?
    In csh you'd do:
    set path = (<MMSIMinstDir>/tools/bin $path)
    Or in bash/ksh:
    export PATH=<MMSIMinstDir>/tools/bin:$PATH
    You must have something similar to get "virtuoso" in your path from the IC stream.
    (Note, you need to replace the correct path for <MMSIMinstDir> in the above; this is very basic UNIX stuff).
    If it doesn't know where the spectre executable is, there's no way ADE can execute it.
  • Andre Mansano
    I want to use the AMS simulator to simulate a system including the VerilogA models and get the same error of ADE-Explorer-1612 error: Simulator no in path. I have tried the mentioned solution but it didn't work out.
    The only difference is that in my MMSIMinstDir we have a Dir named "tools.lnx86" instead of "tools". I also made a new test bench but still the problem exists.
    I am using Virtuoso IC6.1.7.
    I would appreciate if you suggest another solution.
    Andre
