  3. Inverter gpdk180 DRC error. NWELLterm NWVIA : No Stamped...
  • Subscribers 133
  • Views 17910
Inverter gpdk180 DRC error. NWELLterm NWVIA : No Stamped Connections
althoff
althoff over 13 years ago
I`m new, studying electronics and this beginning has been though.
I`ve tried to create a Inverted using gpdk180 technology, but the "NWELLterm NWVIA : No Stamped Connections" keeps popping up every time I make the layout for the PMOS.
I similar problem was occurring with the NMOS part. It showed up the "PSUB SUBVIA : No Stamped Connections." and I handled that with a M1_PIMP connection. The same solution (with M1_Nwell) has not happened for the PMOS in the INVERTER. Everytime I run the DRC it gives me that error and it highlights the PMOS i`ve created. I`ve tried to solve it in different ways, but it seems I dont quite understand what is the NWVIA that the NBurried requires to be connected with the M1.
Any1 have some thoughts?
I`ve put some pics so every1 can see what i`m trying to create.
Tnx,
DRC Shows Error
Project
  • Quek
    Quek over 13 years ago
    Hi Althoff
    I think using M1_Nwell via should have solved the problem. Would you please post a picture of your inverter?
    Quek
  • althoff
    Hey, I solved it.
    It was actually quite simple. The pics are posted bellow, I dont know why they didnt appear on the post, but if you grap the URL and put it in the browser it will redirect you.
    Apparently, since I was not using the PMOS and NMOS from the gpdk180 lib, I shouldnt have used another via. I should've construtec the via inside the Nwell from the PMOS, instead of creating another via with a new Nwell or using a via M1_Nwell.
    Thanks, though, for your interest in my problem.
