  3. Cellviews missing cdb2oa
  • Subscribers 132
  • Views 15500
benben6688
benben6688 over 13 years ago
 I convert a design from IC5.1 to IC6.1.5 and I see that three OA cells have no views in the library manager. I try to translate this cells again with different parameters, but they are still empty (each cell has two views in CDB: 'abstract' ans 'layout'). The log file says that cdb2oa did the translation:
INFO (CDBOA-800): Translating cellview ........
 Has anyone an idea about this problem?
Benoit.
  • Alex Soyer
    Alex Soyer over 13 years ago
    Hello Benoit,
     Did you look at what is on the disk ?
    Alex
  • benben6688
    Yes, there is only two files in their folders: '.abstract.messages' and '.abstract.status'.
    Benoit
  • Alex Soyer
    Benoit,
     Please check teh size of the original cellviews.
    Please check as well the cellviews are correctly referencing technology library and teh technology library is same on the OA side.
    Alex
  • benben6688
    I check everything, there is no problem with the size of the original cellviews and they are referencing the technology library. And the technology library is same on the OA side.
    Benoit
