  3. ADE simulates, won't display results
  • Subscribers 133
  • Views 5131
Kaou
Kaou over 13 years ago
When I run a simulation from ADE L, it appears to complete; however, when it tries to display the results (or I try to open a results browser) I get the following output on the command window:
Loading viva.cxt
Segmentation fault
ERROR (WIA-1118): Failed to launch Visualization & Analysis Tool because of a problem in the DFII
            installation hierarchy 'Exit Code = 219'. Contact Cadence Customer Support with the diagnostic
            information in the log file '/media/DATA/Cadence/ade_viva.log'.
INFO (WIA-1116): Writing diagnostic information.
ERROR (WIA-1100): Unable to establish connection with Visualization & Analysis Tool. For assistance,
            contact Cadence Customer Support with the diagnostic information in the log file '/media/DATA/Cadence/ade_viva.log'.
ERROR (WIA-1105): Failed to get the MPS handle.
simulation completed successfully.
reading simulation data...
      ...successful.
Loading hspiceD.cxt
Loading UltraSim.cxt
Loading AMSOSS.cxt
Loading AMS.cxt
*WARNING* aaTriggerEvent2: error calling (lambda((_simID status) _sevAfterSimulationWrapper('sevSession1 status)) t (stdobj@0x121913d8 nil nil)) ("funcall" 0 t nil ("*Error* funcall: argument #1 should be a function object or name (type template = \"ug\")" nil)).
This started happening when I was trying to troubleshoot ADE GXL (similar issue to www.cadence.com/.../13377.aspx) and I installed libgdbm.so.2 to a folder in my path. ADE L used to work on this system, which is a Debian Wheezy installation using the NCSU CDK and now it won't. Any help in getting this issue resolved would be much appreciated.
     What version are you using? What does the "diagnostic information in the log file..." say? Did you do what it said and contact Customer Support?
    BTW, Debian is not a supported platform.
  • Kaou
    I am running Virtuoso version 6.1.3 05/19/2010 01:23 (cic612lnx) $ sub-version IC6.1.3.500.19 (32-bit addresses).
    The ade_viva.log  says ithe Visualization & Analysis Tool exited with exit code 219 after running checkwavescan Revision: 1.14.16.1.
    The only errors I could find in the log are:
    === 1st Error ===
    >>> Running sum (0xf76ee000):
    sum: (0xf76ee000): No such file or directory
    Configuration checks failed, status is: FAIL
    Your system is Linux, but apparently not RedHat or SuSE.
    Only these vendors are supported by Cadence at this time.
    breaksw: endsw not found.
    === 2nd Error ===
    >>> Running date:
    Thu Sep 13 20:07:20 EDT 2012
    output saved in /media/DATA/Cadence/ade_viva.log
    /usr/local/Cadence/tools/dfII/bin/viva[75]: .[882]: .: line 4: 20481: Memory fault
    /usr/local/Cadence/tools/dfII/bin/viva[75]: .[882]: .: line 5: 20482: Memory fault
    /usr/local/Cadence/tools/dfII/bin/viva[75]: .[882]: .: line 25: 20483: Memory fault
    /usr/local/Cadence/tools/dfII/bin/viva[75]: .[882]: .: line 65: 20484: Memory fault
    === End Error ===
    I'm not the administrator for our university's Cadence installation, so I don't have access to Customer Support.
  • Kaou
    Running Virtuoso from the university servers gives me the following error:
    Loading viva.cxt
    Could not create the Java virtual machine.
                installation hierarchy 'Exit Code = 81'. Contact Cadence Customer Support with the diagnostic
                information in the log file '/home/aonokenj/ade_viva.log'.
    *WARNING* aaTriggerEvent2: error calling (lambda((_simID status) _sevAfterSimulationWrapper('sevSession2 status)) t (stdobj@0x12e6e024 nil nil)) ("funcall" 0 t nil ("*Error* funcall: argument #1 should be a function object or name (type template = \"ug\")" nil)).
    Could this be an issue with my local machine's Java installation? I have seem past forum entries suggest that users switch to AWD instead of Wavescan, but this isn't even an option in 6.1x is it? How would I go about debugging this issue?
  • Tawna
    Tawna over 13 years ago
    If checkSysConf is failing, you need to get your system administrator involved to upgrade patches/OS/etc. on your machine.
    A requirement of Cadence software running successfully is checkSysConf passing.
    Also, you are using a pretty old version of IC tools.  Currently IC6.1.5 is the most recent release.
    Best regards,
    Tawna
  • Kaou
    This was indeed a problem on the local machine. I had recently updated Debian to the multiarch setup, and had copied some files around (including to the servers). As it turns out, a backup copy of `libc.so.6' got placed in one of the $PATH directories that Cadence was configured for. Removing the old `libc.so.6' has fixed the problem. As a side note, adding `libgdbm.so.2' to the $PATH and commenting out the `cd' and `ls' nprocedures in $NCSU_CDK/skill/misc/opusUnix.il fixed my original problem with getting ADE GXL to work.
