  3. Layout XL connectivity for flattened transistors
  • Subscribers 133
  • Views 15185
Allan Wang
Allan Wang over 13 years ago
How do I keep connectivity working properly when I flatten transistors? Specifically, the diffusion regions that are different nets but need to touch in order to form a transistor. If I draw two RX rectangles touching each other under  a gate for the drain and source, then connectivity thinks I'm shorting the two rectangles together.
I'm currently using ic-5.1 but I had the same problem in the latest 6.1.5
  • Allan Wang
    Bump... I'd still like to know this...
  • vvacad
    vvacad over 13 years ago
    Hi Allan,
     For 6.1.5, this is available using stop layer specifications, please refer to:
    http://support.cadence.com/wps/PA_DocumentViewer/pubs/vxlhelp/vxlhelp6.1.5/chap2.html#extractorinfo
    Also, the lxBlock* properties on shapes can be used to control the extraction. These properties (but not the stop layers) are also available in 5.1.x,
    Vikram
