  3. The label of created pin disappeared
  • Subscribers 132
  • Views 15682
bobbygang
bobbygang over 13 years ago
Haven't seen you for a long time because I changed to a customer support post.
However,sometimes I still need to help coworker do some software support work.
We met a strange problem,
I create a script like following to create pin in schematic:
* Customized REDS Schematic Menu Generate Symbol
* Source: ~/menus/schematic_geSym.il,v
* Ver        1.0
* Author     Andy Zhu
* Group      AOC1 , Ricoh Electronic Design Shanghai Systems Ltd .
* Language   CSHELL
* Date       Nov 04, 2011
* Modified   Sep 20, 2011
; The following define the sliders that appear in more than one pulldown
; menu set. They are defined here to avoid incorrectly changing one instance
; of a menu item without changing all instances.
procedure(Ch_Str(in_String type)
   case(type
         (stRlen  if(length(parseString(in_String))>1 then
                    nil
                  else t
                    ) ;end if
         (stRlet  rexMatchp("[a-zA-Z]" in_String)
         (stRnumb rexMatchp("[0-9]" in_String )
       ) ;end case
) ;end procedure
procedure( rSI1LibBrowser( )
ddsSyncWithForm( reds_SchM_It2_Form 'browse 'rSI1_libname 'rSI1_cellname)
) ;end procedure
procedure(rSI1_ErrorDBox(errorText)
hiDisplayAppDBox(
?name gensym( 'rSI1_errorDialogBox ) ; unique variable
?dboxBanner "Put Pin Info"
?dboxText strcat(errorText " Error ! ")
?dialogType hicErrorDialog
?dialogStyle 'modal
?buttonLayout 'Close
) ;end procedure
procedure(rSI1_CompleteDBox(completeCellText completeLibText)
hiDisplayAppDBox(
?name gensym( 'rSI1_completeDialogBox ) ; unique variable
?dboxText strcat("Put Pin in Cell " completeLibText " -> " completeCellText " Completed ! ")
?dialogType hicInformationDialog
?dialogStyle 'modal
) ;end procedure
procedure(reds_SchM_It1_Put_Pin()
let((rSI1PFB rSI1PFBrBn rSI1LibName rSI1CellName rSI1LibBrowserBn rSI1PinLength rSI1PinSpace rSI1FontSize
    rSI1default_file rSI1PFB_filename_Def rSI1_libname_Def rSI1_cellname_Def rSI1_pinspace_Def rSI1_pinlen_Def rSI1_fontsize_Def)
    rSI1_window=hiGetCurrentWindow()
    rSI1_cellViewId=deGetCellView(rSI1_window 0)
    rSI1F_lib=rSI1_cellViewId~>libName
    rSI1F_cell=rSI1_cellViewId~>cellName
    rSI1default_file=infile("~/menus/.REDSPutPin_list")
    fileSeek(rSI1default_file 13 0)
    fscanf(rSI1default_file "%s" rSI1PFB_filename_Def)
    fileSeek(rSI1default_file 14 1)
    fscanf(rSI1default_file "%s" rSI1_pinspace_Def)
    fileSeek(rSI1default_file 15 1)
    fscanf(rSI1default_file "%s" rSI1_pinlen_Def)
    fileSeek(rSI1default_file 8 1)
    fscanf(rSI1default_file "%s" rSI1_fontsize_Def)
    close(rSI1default_file)
    if(rSI1_pinlen_Def == "nAn" then
      rSI1wireenbtn_Def=nil
      rSI1_pinlen_en=nil
    else
      rSI1wireenbtn_Def=t
      rSI1_pinlen_en=t
    ) ;end if
    rSI1PFB = hiCreateStringField(
    ?name 'rSI1PFB_filename
    ?prompt "Pin List File"
    ?value rSI1PFB_filename_Def
    ?callback "rSI1PFB_callback(hiGetCurrentForm() 'strFileNameField)"
    rSI1PFBrBn = hiCreateFormButton(
    ?name 'rSI1PFB_btn
    ?buttonText "Browse..."
    ?callback "ddsFileBrowseCB( hiGetCurrentForm() 'rSI1PFB_filename \"*.txt\" 'existingFile)"
    rSI1WireEnBn = hiCreateBooleanButton(
    ?name 'rSI1wireen_btn
    ?buttonText "Add wire"
    ?value rSI1wireenbtn_Def
    ?callback "rSI1WireEnBn_callback(hiGetCurrentForm())"
    rSI1PinLength = hiCreateStringField(
    ?name 'rSI1_pinlen
    ?prompt "Pin Wire Length"
    ?value rSI1_pinlen_Def
    ?callback ""
    ?enabled rSI1_pinlen_en
    rSI1PinSpace = hiCreateStringField(
    ?name 'rSI1_pinspace
    ?prompt "Pin Space"
    ?value rSI1_pinspace_Def
    ?callback ""
    rSI1FontSize = hiCreateStringField(
    ?name 'rSI1_fontsize
    ?prompt "Symbol Font Size"
    ?value rSI1_fontsize_Def
    ?callback ""
    hiCreateAppForm(
    ?name    'reds_SchM_It1_Form
    ?formTitle "Put Pin From Pin List File"
    ?callback   "rSI1PFB_callback(hiGetCurrentForm() 'Ok)"
    ?fields list(
              list(rSI1PFB 0:0 560:35 110)
              list(rSI1PFBrBn 560:0 80:35)
              list(rSI1WireEnBn 0:35 140:35 )
              list(rSI1PinLength 0:70 320:35 110)
              list(rSI1PinSpace 320:70 320:35 110)
              list(rSI1FontSize 0:105 320:35 110)
    ?attachmentList list(
                     hicTopPositionSet | hicLeftPositionSet  | hicRightPercentSet
                     hicTopPositionSet | hicLeftPercentSet   | hicRightPositionSet
    ?initialSize list( 640 140)
    ?buttonLayout '(Empty (Create\ and\ Cancel "hiFormApply(hiGetCurrentForm()) hiFormCancel(hiGetCurrentForm())")  (Create hiFormApply) (Cancel hiFormCancel) (Default hiFormDefaults))
    hiDisplayForm(reds_SchM_It1_Form)
    ddsEndSyncWithForm()
procedure(rSI1WireEnBn_callback(theForm )
if(theForm->rSI1wireen_btn->value == t then
   println("Add Wire Enabled")
   hiSetFieldEnabled(
             rSI1PinLength
             t
else
   println("Add Wire Disabled")
   hiSetFieldEnabled(
             rSI1PinLength
             nil
) ;end if
) ;end procedure
procedure(rSI1PFB_callback( theForm actionOrField)
let( (rSI1_fileInt rSI1_PinLenInt rSI1_PinSpInt rSI1_FSInt
      rSI1PFB_path rSI1PFB_dir rSI1PFB_file rSI1PFB_out rSI1PFB_lib rSI1PFB_cell rSI1PFB_out2 rSI1_Errortext)
case( actionOrField
  ;;; checking if the file exists
      ( strFileNameField
        if( isFile( theForm->rSI1PFB_filename->value ) then
           println("Pin List File Exists")
           t
        else
           println("Pin List File Does Not Exist, Try Again")
           nil
          ) ;end if
      ) ;end strFileNameField
      ( Ok
            rSI1_fileInt  =not(null( rSI1PFB_callback( theForm 'strFileNameField )))
            rSI1_PinLenInt=not(null( rSI1PFB_callback( theForm 'strPinLenField )))
            rSI1_PinSpInt =not(null( rSI1PFB_callback( theForm 'strPinSpaceField )))
            rSI1_FSInt    =not(null( rSI1PFB_callback( theForm 'strSymFontSizeField )))
            if(rSI1_fileInt && rSI1_PinLenInt && rSI1_PinSpInt && rSI1_FSInt then
                rSI1PFB_path=theForm->rSI1PFB_filename->value
                rSI1PFB_path=simplifyFilename(rSI1PFB_path)
                rSI1PFB_dir=strcat("/" buildString(reverse(cdr(reverse(parseString(rSI1PFB_path "/")))) "/"))
                rSI1PFB_file=car(reverse(parseString(rSI1PFB_path "/")))
                rSI1PFB_out=outfile("~/menus/.putPin_P" "w")
                fprintf(rSI1PFB_out "%s\n" rSI1PFB_path )
                fprintf(rSI1PFB_out "%s\n" rSI1PFB_dir )
                fprintf(rSI1PFB_out "%s" rSI1PFB_file)
                close(rSI1PFB_out)
                rSI1PFB_out2=outfile("~/menus/.REDSPutPin_list" "w")
                fprintf(rSI1PFB_out2 "Pinlist_Path=%s\n" rSI1PFB_path)
                fprintf(rSI1PFB_out2 "symwireSpace=%s\n" rSI1F_pinsp)
                if(theForm->rSI1wireen_btn->value then
                  fprintf(rSI1PFB_out2 "symwireLength=%s\n" rSI1F_pinlen)
                else
                  fprintf(rSI1PFB_out2 "symwireLength=nAn\n" )
                ) ;end if
                fprintf(rSI1PFB_out2 "sym_fH=%s\n" rSI1F_fz)
                close(rSI1PFB_out2)
                csh("~/menus/csh/putPin.il")
                rSI1F_input=infile("~/menus/.rSI1_Pin")
                rSI1F_pinX=0
                rSI1F_pinY=0
                rSI1F_cyle=0
                while(fscanf(rSI1F_input "%s" rSI1F_pinname)!=nil
                  cond((rSI1F_cyle==0
                        rSIF_pinNAME_L=rSI1F_pinname)
                       (rSI1F_pinname=="rSI1_Input_Pin"&&rSI1F_cyle>0
                        rSI1F_pinSym="ipin"
                        rSI1F_pinmode="input")
                       (rSI1F_pinname=="rSI1_Output_Pin" &&rSI1F_cyle>0
                        rSI1F_pinX=rSI1F_pinX+2*evalstring(rSI1F_fz)+0.125
                        rSI1F_pinY=0
                        rSI1F_pinSym="opin"
                        rSI1F_pinmode="output")
                       (rSI1F_pinname!="rSI1_Input_Pin" &&rSI1F_pinname!="rSI1_Output_Pin" &&rSI1F_cyle>0
                        rSI1F_pinCVId=dbOpenCellViewByType( "basic" rSI1F_pinSym "symbol" "" 'r )
                        rSI1F_pinXY=list(rSI1F_pinX rSI1F_pinY)
                        rSI1F_pinId=schCreatePin( rSI1_cellViewId rSI1F_pinCVId rSI1F_pinname rSI1F_pinmode nil rSI1F_pinXY "R0" )
                        rSI1F_pinId~>children~>font="roman"
                        rSI1F_pinId~>children~>height=evalstring(rSI1F_fz)
                        if(abs(rSI1F_pinY)>=20*evalstring(rSI1F_pinsp)  then
                          rSI1F_pinX=rSI1F_pinX+(1+evalstring(rSIF_pinNAME_L))*evalstring(rSI1F_fz)+0.125
                          rSI1F_pinY=0
                        else
                          rSI1F_pinY=rSI1F_pinY-evalstring(rSI1F_pinsp)
                          ) ;end if
                       ) ;end cond
                   rSI1F_cyle=rSI1F_cyle+1
                ) ;end while
                close(rSI1F_input)
                rSI1_CompleteDBox(rSI1F_cell rSI1F_lib)
            else
                rSI1_Errortext=nil
                if(rSI1_fileInt==nil then
                  rSI1_Errortext=tconc(rSI1_Errortext "Pin List File")
                ) ;end if
                if(rSI1_PinLenInt==nil then
                  rSI1_Errortext=tconc(rSI1_Errortext "Pin Wire Length")
                ) ;end if
                if(rSI1_PinSpInt==nil then
                  rSI1_Errortext=tconc(rSI1_Errortext "Pin Space")
                ) ;end if
                if(rSI1_FSInt==nil then
                  rSI1_Errortext=tconc(rSI1_Errortext "Symbol Font Size")
                ) ;end if
                rSI1_Errortext=buildString(car(rSI1_Errortext) " & ")
                rSI1_ErrorDBox(rSI1_Errortext)
              ) ;end if
  ;;; checking the Pin Length
      (strPinLenField
          rSI1F_pinlen=theForm->rSI1_pinlen->value
          if((rSI1F_pinlen != "") && Ch_Str(rSI1F_pinlen 'stRlen) && Ch_Str(rSI1F_pinlen 'stRlet)==nil && Ch_Str(rSI1F_pinlen 'stRnumb)  then
             println("Pin Wire Length Ok")
             t
          else
             println("Pin Wire Length Error, Try Again")
            nil
            ) ;end if
        else
          t
          ) ;end if
      ) ;end strPinLenField
  ;;; checking the Pin Space
      (strPinSpaceField
        rSI1F_pinsp=theForm->rSI1_pinspace->value
        if((rSI1F_pinsp != "") && Ch_Str(rSI1F_pinsp 'stRlen) && Ch_Str(rSI1F_pinsp 'stRlet)==nil && Ch_Str(rSI1F_pinsp 'stRnumb)  then
           println("Pin Space Ok")
           t
        else
           println("Pin Space Error, Try Again")
           nil
          ) ;end if
      ) ;end strPinSpaceField
  ;;; checking the Font Size
      (strSymFontSizeField
        rSI1F_fz=theForm->rSI1_fontsize->value
        if((rSI1F_fz != "") && Ch_Str(rSI1F_fz 'stRlen) && Ch_Str(rSI1F_fz 'stRlet)==nil && Ch_Str(rSI1F_fz 'stRnumb)  then
           println("Symbol Font Size Ok")
           t
        else
           println("Symbol Font Size Error, Try Again")
           nil
          ) ;end if
      ) ;end strSymFontSizeField
      ( t
        error( "Illegal action or unknown field: %L" actionOrField )
    ) ; end case
) ;end let
) ;end procedure
It can create pin easily but when I move the pin and save the schematic, sometimes the label will disappear.
What's the possible reason?
 Looking forward to your reply!
Thank you!
BR,
Bobby
