  3. how to run APS in ocean
  • Subscribers 133
  • Views 15895
zwang
zwang over 13 years ago
I am trying to runing APS with ocean script. How can I do that? Please advise.
  • Quek
    Quek over 13 years ago
    Hi zwang
    You can add the following section in your script:
    option(
       ?categ 'turboOpts
       'uniMode "APS"
    Best regards
    Quek
  • zwang
    Hi Quek,
    It worked. But, it got too many licenses(6 of them). With ADE, I can set "Multithreading options" as "manual" and "number of threads" as 1 to limit the number of licenses down to 2. Can I do the same with Ocean Script? Thank you.
    Zhenyu
  • zwang
    HI Quek,
    Sorry. I figured it out. I can export the oceanscript from ADE. It has the option to limit the number of license. Thank you for the help!
    Zhenyu
  • Quek
    Hi Zhenyu
    That's great. Thanks for the update. Using ADE to generate an oceanscript is the easiest method to get the required cmds. You can also refer to $CDSHOME/doc/oceanref/oceanref.pdf.
    Best regards
    Quek
