  3. VerilogA parsing problem
  • Subscribers 133
  • Views 18955
StanleyN
StanleyN over 13 years ago
When I check and save a verilogA file from cadence library, cadence always checks the syntax of the VerilogA file.
But now if I do it, I got the following error
WARNING : There is some issue in invoking spectre command for parsing the text file  <path to verilogA file>
         Make sure that the setting is proper
Error: Failed syntax check for veriloga text of cell <cellname>
What setting should I change?
Thanks for your help
    Andrew Beckett over 7 years ago in reply to subramanya007 +1
    I did some checks, and this can happen if rather than having spectre from a Cadence MMSIM or SPECTRE installation in your path, you have a wrapper script called "spectre" in your path. So if "which spectre…
    You probably don't have spectre in your UNIX path before you start virtuoso. If you type "which spectre" from the UNIX command line, it needs to find spectre. This would be solved by adding <MMSIMinstDIr>/tools/bin to your $path variable (in csh) or $PATH variable (in sh/bash/ksh).
  • subramanya007
    subramanya007 over 7 years ago in reply to Andrew Beckett
    I have the same issue, but spectre is on my unix path. Typing "which spectre" gives the path of the spectre command line being used. What else could be causing this?
    I did some checks, and this can happen if rather than having spectre from a Cadence MMSIM or SPECTRE installation in your path, you have a wrapper script called "spectre" in your path. So if "which spectre" doesn't give a path like <SPECTREinstDir>/bin/spectre or <SPECTREinstDir>/tools/bin/spectre (where <SPECTREinstDir> is the root of one of our installations) you may have this problem.
    What the code actually checks is whether the "feature" information can be found. We have a number of things in the IC environment which are adapted depending on the capabilities of the MMSIM/SPECTRE installation you have in your path. With a direct path to the spectre installation, this can be found, but if a wrapper script is in the way, it can't...
    The workaround (and you should only do this if you are using a wrapper) is to set the SPECTRE_FEATURE_FILE UNIX environment variable before starting virtuoso:
    setenv SPECTRE_FEATURE_FILE /export/home/apps/SPECTRE171_isr/tools/spectre/etc/files/features.dat
    or
    export SPECTRE_FEATURE_FILE=/export/home/apps/SPECTRE171_isr/tools/spectre/etc/files/features.dat
    (of course, the /export/home/apps?SPECTRE171_isr bit will depend on where your SPECTRE/MMSIM installation is located, and whether you use setenv or export will depend on whether you're using csh or ksh/bash).
  • subramanya007
    Great! That worked. You are awesome.
