  3. Method to control subcircuit order when generating a Spectre...
  • Subscribers 131
  • Views 7513
Method to control subcircuit order when generating a Spectre netlist?
FormerMember
FormerMember over 13 years ago
Is there a way to control the order of subcircuits in when generating a netlist in Spectre? The motivation for the question is to faciliate the inspection of two netlists of a similar block. The netlister does not appear to place the subcircuits (even though they appear to be identical in the two netlists) in the same order when I inspect the netlists.
I found a section in the SKILL manual that appears to allow control of the netlisting manual, but it was not clear to me how the commands I found how to control the order in which subciruits are placed when generating a netlist.
Thank you, for any insights anyone may have....
    I don't believe this is possible.
    ShawnLogan over 13 years ago
    Thank you! Not great news - but you saved me a lot of time!
    Shawn
