  3. help with non-existent pin
  • Views 19650
linbo
linbo over 13 years ago
Hi All,
 We're trying to run a post extracted simulation and the simulator won't netlist.
Error message reads:
ERROR (OSSHNL-249): There is no corresponding terminal for 'zorchp' (on placed master 'ind_diff_1p95n_ef/layout') in....
A long time ago when I was doing the layout of the cell mentioned I added a pin named zorchp.  It is no longer there.  It does not exist in the layout, av_extracted (extracted), schematic, or symbol views in this level or any level of the hierarchy.  There are no other views.
It seems as though the cdf parameters got stuck.  We tried re-creating the symbol view in order to force the cdf params to update, indeed the tool asked us if it was ok to overwrite them and we answered affirmatively.
 I have two questions:
1) How do we correct the non-existent terminal and get the tool to netlist
2) Is there a setting or env variable that we can set to ignore unused terminals.
  • Quek
    Quek over 13 years ago
    Hi Linbo
    Here are my comments:
    1. If you do not wish to re-generate the symbol, you can use a skillscript to sync the terminals between symbol and CDF termOrder section.
    2. You can add the following variable to your .simrc file:
    simCheckTermMismatchAction="ignore"
    Best regards
    Quek
  • Eduard Raines
    Eduard Raines over 13 years ago
    You can use dbFindTermByName(d_cellView t_name ) function to find this terminal and dbDeleteObject( d_object  ) to delete it.
    Something like:
    Open your layout
     cv=geGetWindowCellView()
    myTerm = dbFindTermByName(cv "zorchp")
    dbDeleteObject(myTerm)
    Hope it helps.
    Eduard Raines
