  3. Re: How do I call "load /path/usr/test.il" using bindkeys...
  • Subscribers 132
  • Views 3537
Re: How do I call "load /path/usr/test.il" using bindkeys?
Rahim Abdulla
Rahim Abdulla over 13 years ago
 Hi
Can you please help me in this regard.
I would like to load a skill script using a bindkey in virtuoso.
like key 1 for load "/path/usr/test.il"
Rahim.
  • Rahim Abdulla
    Hi
    Rahim
    hiSetBindKey("Schematics" "<Key>1" "load(\"/path/usr/test.il\")")
    Better would be to define a function inside test.il and then your bindkey can call it and not keep loading the file each time.
  • Deepon Saha
    Deepon Saha over 13 years ago
    Hello Rahim,
    Its quite simple, at first check if you have a .cdsinit file in the library (the folder in which you run virtuoso), if not create one/add the following lines:
    load(prependInstallPath("/path/test.il"))
    So, the script will be automatically loaded, now in the script, use the bindkey command so that the particular function is loaded whenever you press a certain key.
    eg.: bk("Layout" "<Key>up"   "geScroll(nil \"n\" nil)")
    [This will bind the graphics editor (ge) function to scroll with the 'up' key.]
    Let me know if you need any further help.
