  3. Operaing point regions Guide
  • Subscribers 133
  • Views 20779
fighter84
fighter84 over 13 years ago
where can i fin a table with the operaing point regions of mosfets and bjts in ADE?
From the help i found region 2-->saturation for mosfet and region 3--> saturation for bjt
but i can't find a completely guide.
Can you help me? Thanks
  • berndfi
    berndfi over 13 years ago
    You simply could do form command line
    spectre –h <component> e.g bsim3v3
    and search for the region parameter.
    For the MOS bsim3v3 models it is
    region=triode
     Estimated operating region. Spectre outputs number (0-4) in a rawfile.
     Possible values are off, triode, sat, subth, and breakdown.
    Bernd
  • fighter84
     Sorry,
    i need to understand spectre output numbers for bjt and mosfets.
    Bernd told you precisely how to do this. First find out what model your bjts and mosfets are using - if it was "bjt" then you'd do "spectre -h bjt". If the bjt was using  "vbic", you'd do "spectre -h vbic" and so on (similar for the mosfets). You can see the available models using "spectre -h".
