  3. ADE XL doesn't work. ERROR (ADEXL-5025)
  • Subscribers 130
  • Views 6636
habet
habet over 13 years ago
Hello everyone,
I am using Cadence IC6.1.5-64b.500.9  (64-bit addresses) for my design.
The simulation with ADE L works well. I want to use ADE XL to do monte carlo simulation so, it doens't work. I tried a single run with ADE XL, it doesn't work also and it gives this message's error.
ERROR (ADEXL-5025): Preparation to run the simulation is failed for the run Interactive.24, point 1, test
 Error while preparing to run the simulation.
 Cannot copy "netlist into run netlist" from "/home/xxx/simulation/TEST/emeteur_commun/adexl/results/data/Interactive.24/1/TEST:emeteur_commun:1/netlist" to "/home/xxx/simulation/TEST/emeteur_commun/adexl/results/data/Interactive.24/psf/TEST:emeteur_commun:1/netlist", cpDataDir call returned 0
 For details open log: /home/xxx/Qubic4X_wrk/logs_xxx/Job8.log for the point: (0 1)
 did someone met this problem ?
Thank you for your help.
Abdel
  • Matrixesque
    Matrixesque over 13 years ago
    I also seem to have this problem, and the log file is no help.
    ERROR (ADEXL-5025): Preparation to run the simulation is failed for the run Interactive.1, point 1, test RNG:default_ell_filter:1, received error:
    Error:
     Cannot copy "netlist into run netlist" from "/root/simulation/RNG/default_ell_filter/default_ell_view/results/data/Interactive.1/1/RNG:default_ell_filter:1/netlist" to "/root/simulation/RNG/default_ell_filter/default_ell_view/results/data/Interactive.1/psf/RNG:default_ell_filter:1/netlist", cpDataDir call returned 0
     For details open log: /home/rguerra/logs_root/Job2.log for the point: (1 1)
    For more details, consult the job log file:
    However, when I go and take a look at the log, there is no helpful information there. Perhaps this error number means something to someone somewhere. I would normally associate a return value of 0 to be a good sign, but it seems that isn't the case here. Virtuoso is run as root with root permissions.
    \o Netlisting Statistics:
    \o Number of components:    4
    \o
    \o Elapsed time:          0.0s
    \o Errors: 0 Warnings: 0
    \o       ...successful.
    \o compose simulator input file...
    \o       ...successful.
    \e *Error* Error during netlisting of design for the point ID (1 1).
    \e ("error" 1 t nil ("*Error* Cannot copy \"netlist into run netlist\" from \"/root/simulation/RNG/default_ell_filter/default_ell_view/results/data/Interactive.1/1/RNG:default_ell_filter:1/netlist\" to \"/root/simulation/RNG/default_ell_filter/default_ell_view/results/data/Interactive.1/psf/RNG:default_ell_filter:1/netlist\", cpDataDir call returned 0"))
    \e
    \e
    \o
    \o *Error*   Error ID  = 5025
    \o *Error*   Error Msg = Error while preparing to run the simulation.
  • Matrixesque
    FWIW, this is on IC6.15.011 with MMSIM11.1
  • Matrixesque
    Following up with my solution to this problem. I had assumed that cpDataDir was a SKILL command and was thus implemented internally. Turn out this is not the case--this is a simple problem of incomplete tool paths. As per Cadence customer service, in a csh environment, the system path should look like the following:
    set path = ( $MMSIMHOME/tools/bin \ $CDSHOME/tools/bin \ $CDSHOME/tools/dfII/bin \ $CDSHOME/tools/plot/bin \ $CDSHOME/tools/etc \ /usr/local/bin $path )
    In my bash environment, my setup is the same but with different syntax:
    • export CDSHOME=/root/cadence/installs/IC615
    • export MMSIMHOME=/root/cadence/installs/MMSIM111
    • export PATH=$PATH:$MMSIMHOME/tools/bin
    • export PATH=$PATH:$CDSHOME/bin
    • export PATH=$PATH:$CDSHOME/tools/bin
    • export PATH=$PATH:$CDSHOME/tools/dfII/bin
    • export PATH=$PATH:$CDSHOME/tools/plot/bin
    • export PATH=$PATH:$CDSHOME/tools/etc/bin
    The key is that the cpDataDir executable is located in $CDSHOME/tools/dfII/bin.
    Best of luck to any Googlers!
