  3. transient analysis for CV plot
  • Subscribers 132
  • Views 18349
soathana
soathana over 13 years ago
Hi everyone,
I want to maka a CV plot of MOSFET capacitances. By using ac analysis this is easy. The problem is that i want to keep all dc sources because they are used to bias some other controlling part of circuit. In essense I want to do transient analysis and sweep a dc source at the same time. How is this possible through cadence?
thanks,
sotiris
    Hi Sotiris,
    How do you want to sweep the source? It's not that clear to me. You could make the source a vsource from analogLib which is a pulse source ramping the value up during the transient; in non-transient analyses it will use the dc value of this source (if supplied) or the time-zero value if the dc value is not supplied.
    Or you could use the dynamic parameters capability of tran analysis to ramp up a variable (assigned as the value of the source) over time.
    Or you could use parametric analysis to sweep the source separately from the time sweep (this is if you want the sweeps to be orthogonal).
    As you can see I'm having to guess a little what your objective is.
  • soathana
    Hi Andrew and thanks for your fast response!
    I am using a vsin source and i want for a specific frequency to sweep its dc offset (or a dc voltage source in series).
    thanks,
    Sotiris
    Sotiris,
    It's still not that clear to me...
  • soathana
    Ok, probably it is Dynamic parameter option... I will work it out
    thanks,
    sotiris
    Sotiris,
    OK, so are you expecting to have a vsin source with a specific frequency, and then have the DC voltage change during the transient simulation. Or do you want to several transient simulations with different DC offsets?
  • soathana
    sorry for the many edits. I need a vsin source with a specific frequency, and then have the DC voltage change during the transient simulation. I tried with dynamic parameters a little bit, so I made a file for DC voltage with respect to time:
    "tscale 1e-6
    time value
    0   -5
    100 -4.5
    2000 5"
    And I have tran 2m.
    Is this the way to do it? Also is there a way to make it look more continuous. When I plot it with respect to time i get steps...
    Also is there a way to plot versus the dynamic parameter instead of time?
    Sotiris
