  3. BUS in extracted view
  • Subscribers 132
  • Views 16173
Zdeno
Zdeno over 13 years ago
I am simulating extracted view in ADEXL. I use OSS-based netlister to create netlist. Extracted view contains nets:
cnf_reg_analog<15>
cnf_reg_analog<14>
cnf_reg_analog<3>
I want to merge all nets to one bus as it is in my verilog netlist:
output [15:3] cnf_reg_analog;
but I got the message:
WARNING (VLOGNET-186): Unable to generate explicit netlist for the 'z_chip_def/cell/extracted_rc' cell view because split buses and/or bundle terminals are present in it.
Set the Terminal SyncUp option on the Netlist Setup form as 'Merge All' or set the hnlVerilogTermSyncUp variable as 'mergeAll' and netlist again.
And netlist looks like:
module cell (cnf_out, \cnf_reg_analog(15) , \cnf_reg_analog(14) ,
\cnf_reg_analog(13) , \cnf_reg_analog(12) , \cnf_reg_analog(11) ,
\cnf_reg_analog(10) , \cnf_reg_analog(9) , \cnf_reg_analog(8) ,
\cnf_reg_analog(7) , \cnf_reg_analog(6) , \cnf_reg_analog(5) ,
\cnf_reg_analog(4) , \cnf_reg_analog(3) , cnt_out, gnd, vdd, clk,
clk_cnt, cnf_en, cnf_in, cnt_in, hit, rst, shutter);
output cnf_out, \cnf_reg_analog(15) , \cnf_reg_analog(14) ,
\cnf_reg_analog(4) , \cnf_reg_analog(3) , cnt_out;
I tried to set hnlVerilogTermSyncUp to 'mergeAll', also to 'honorSM' without any effect. I can not find even SyncUp option in Netlist Setup.
I use:
IC06.15.506-615, MMSIM10.11.200, INCISIV10.20.026
Is there any solution how to create BUS from nets in extracted view?
Thank you very much for the answer.
Best Regards
Zdeno
  • Zdeno
    no one has idea how to correct this problem? Still I can not plot signal from bus In ADEXL with following error:
    ERROR (WIA-1006): Unable to plot expression <VT("/cnf<3>" "/home/zdenko/simulation/z_chip_sim/cell/adexl/results/data/Interactive.143/psf/tran")>
    because it does not evaluate to an object that can be plotted, like a waveform or
    parametric wave. See the Visualization & Analysis Tool documentation for information
    about the types of objects that can be plotted in Visualization & Analysis Tool. Only
    the expressions that evaluate to those objects can be plotted.
    *Warning* Wave1 is not a waveform object that can be displayed and
    will be DELETED automatically.
    Thanks a lot.
    Zdeno
