  3. .altergroup usage question
  • Subscribers 132
  • Views 15706
GaneshShamnur
GaneshShamnur over 13 years ago
Hi All,
I want to use altergroup in the below scenario of a spectre netlist.
<netlist_section>
I1 (a1) MyCell1
I0 (a1 0 0 0 0 0) MyCell2
tran1 tran stop=10n write="spectre.ic" writefinal="spectre.fc" \
    annotate=status maxiters=5
altTest altergroup {
// I0 (a1 0 0 0 0 0) MyCell2 ( Works well simulating 2nd analysis tran2!)
 I0 (0 a1 0 0 0 0) MyCell2  //(This fails !)
tran2 tran stop=10n write="spectre.ic" writefinal="spectre.fc" \
My intension in trying the above scenario is to change the netlist connection for I0 from 1st-pin[i.e I0(a1 0 0 0 0)] to 2nd-pin[i.e I0( 0 a1  0 0 0)]
Spectre errors out complaining about a connection happening to different node in comparison to earlier definition !
I have also tried another option where the whole subcircuit for I1 instance was redefined in altergroup. This failed too !
Any ideas on how to achieve my objective ?
Ganesh
  • GaneshShamnur
    Hi All,
    I figured out solution to my problem although, it wasn't achievable via altergroup since Spectre-Altergroup( current latest revision as of this writing) doesn't natively support netlist topology modifications.
    Below were two solutions:
    1)  Refer to the link to replicate the suggested method:http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11002322
    2) Include some parameterized components ( e.g: switch/resistor) and control their parameter values in altergroup. Thereby select an appropriate connection.
    e.g: The above problem was solved for first two pins with below netlist, assuming the other 3 pins were grounded. If we were select amongst the other three pins aswell, we need additional 3 pins.
    <netlist_section>
    parameters sw1=1 sw2=0
    I1 (a1) MyCell1
    I2 (a1,out1) MySwitch1 // This switch is ON only when sw1=1 and OFF when sw1=0
    I3 (a1,out2) MySwitch2 // This switch is ON only when sw2=1 and OFF when sw2=0
    I0 (out1 out2 0 0 0) MyCell2
    parameters sw1 = 0 sw2 = 1
     Both have pros and cons to each method.
    1st method would need netlist-modification and oceanscript creation. But the flow can be automated.
    2nd method is additional components insertion into design. But this flow has cleaner netlisting mechanism.
    Ganesh
