  3. stb and ac analysis do not match?
  • Subscribers 133
  • Views 17091
xianweng
xianweng over 13 years ago
 Hi,Guys,I have some problem to understand why stb and ac do not match.When I run stb analyis in a loop,the phase starts from -180 and it increses to a positive value and gain curve is normal! When  I run ac analysis ,it seems like that phase and gain curve are normal  .Could someone tell me which one  simulation  is right?
Thanks any help in advacne
  • Frank Wiedmann
    Frank Wiedmann over 13 years ago
    It's very difficult to tell without seeing your schematics. However, it's normal that the phase starts at -180 degrees (or +180 degrees) in stb analysis (see http://www.designers-guide.org/Forum/YaBB.pl?num=1124688329).
  • xianweng
     Thank you , Frank
     I do not know how to attach a picture on this forum,so I attached it on the http://www.designers-guide.org/Forum/YaBB.pl?num=1352294950/0#0,pleasure click this link to look at the schematic
