  3. Design variables in FFT and THD measures
  • Subscribers 132
  • Views 17172
baenischfau
baenischfau over 13 years ago
I'm currently designing a Class-D output stage and I have come across some
minor problems with the configuration with two of my measurement, namely FFT and THD.
As I always know the frequency(s) of my input signal I wanted to configure the FFT and the
THD measurement to always fit to the period of the output signal. So I defined two variables,
one for the start of the interval and one for the stop, both are integer multiples of the period.
I included those design variables into my measurements as discribed in a different post in this
forum using the desVar() function. For THD this yields in
thd(v("/outp" ?result "tran") desVar("startint") desVar("stopint")  16384 desVar("sigfreq")
for FFT I used the same syntax.
However both measurements do not work. I checked a lot of other measurements with the
desVar() method, they all work fine.
Anyone out there with some pointers ?
Thank you
Best Regards
Andi
    Andi,
    You probably should use the VAR() function, not the desVar() function. desVar returns a string, and that's not what you want here... (I'm surprised it works elsewhere).
  • baenischfau
    Thanks for the hint, however it's still not working.
    What I have tried:
    I use the same set of three variables
    sigfreq = 256k
    startint = 5u
    stopint = startint+5*1/sigfreq
    Staring from
    thd(v(.....) 5u 24.531u 36000 256000)
    I replaced the frequeny setting 256k for the THD measurement with VAR("sigfreq") -> Measurement evaluates fine
    If I replace the starttime with VAR("startint") the measurement already fails,
    drForwardFFT: argument #2 should be a number
    What can I do now ?
    Best Regards
    Andi
    Andi,
    You should report this to customer support. You shouldn't have to do this, but it may well fix it if you change your:
    thd(v(...) VAR("startint") 24.531u ...)
    to:
    famMap('thd v(...) VAR("startint") 24.531u ...)
    I have a CCR for a similar problem with another function, but not with thd. The idea is that famMap copes with unwrapping family data - and so if for some reason the v() is a family, and the VAR("startint") is a waveform (or family) rather than a number, it can sort it out. thd could do this itself.
    It's a bit of a guess, but a similar strategy has worked in other cases for me.
  • baenischfau
    Thanks for your assistance on the matter. I have tried the famMap() option but I still get the same
    error messages. As soon as our local contact for Cadence is back I'll ask him to bring this in to
    customer support.
    Best Regards
    Andi
