  3. QRC Extraction
  • Subscribers 133
  • Views 15822
QRC Extraction
Aram Shahinyan
Aram Shahinyan over 13 years ago
Hello All,
We have PVS LVS and QRC tools in company and the only deck availavle from vendor site  was Assura RC extraction.
Seems Assura deck set does not work good with PVS svdb data, returning errors, etc.
Can you please let me know is there a way to make Assura RC deck working in PVS?
Aram
  • Quek
    Quek over 13 years ago
    Hi Aram
    I am guessing that "Assura deck set" refers to the QRC tech directory (this means the directory that contains the file "qrcTechFile"). Due to the difference in lvs layer names, each flow (PVS-QRC & Assura-QRC) should have their corresponding QRC tech directories. It is possible to modify the "layerSetupFile" or "p2lvsfile" in the QRC tech directory for Assura-QRC flow to make it work for PVS-QRC flow but this requires very extensive modification. I think it is better to get the correct files from your vendor.
    Best regards
    Quek
  • Aram Shahinyan
    Hi Quek,
    Thanks for your information
    Best Regards,
    Aram
