  3. turning off icons near cursor in 6.1.5
  • Subscribers 130
  • Views 14388
linbo
linbo over 13 years ago
Anyone know how to turn off those pesky icons near the cursor in 6.1.5?
    There's a solution on Cadence Online Support which gives a way to do this.
  • linbo
    Thanks for the tip, too bad it isn't straightforwardly implemented.  If you have any input to the process it would be great to have these easily turned off/on with a variable.
    --lin
    You should log a service request with customer support, and explain why it is important to you to be able to disable these. That way the request comes from a real customer rather than just me representing it on behalf of an unnamed individual...
  • linbo
    I actually did file an SR.  They told me "lots of customers specifically asked for this enhancement and Cadence would not be providing a way to turn them off."
     they drive me nuts.  I have so much stuff to sort out visually the last thing I need is more clutter.  I was just hoping for a good workaround.
     tks
  • Tawna
    Tawna over 13 years ago
    Hi TKS,
    Regardless of what you were told, I would request an enhancement CCR be filed on your behalf.
    Reason:  If enough customers request this, the likelihood of the change being made increases.
    Best regards,
    Tawna
