  3. ADEXL: Change config file and re-run simulation automat...
  • Subscribers 132
  • Views 16041
ADEXL: Change config file and re-run simulation automatically
Tobben24
Tobben24 over 13 years ago
I want to do the following 5 times with a new schematic view every time:
1. Run a simulation
2. Switching schematic view on one cell in the config file and re-run
Any one have a good advice on how to do this in ADEXL? I could create 5 tests with 5 different config files? Or is a Cell View restricted to only 1 config file?
    I would probably advise doing it with 5 different config views, and 5 tests. Whilst you could probably code it up to change the config and re-run each time, the benefit of having multiple tests is that you can get all the results together on one page. There's no problem with having multiple config views for a particular design - in fact that's the point!
  • Tobben24
    Ok. Thanks:)
