  3. Skill Code to modify pin names
  • Subscribers 133
  • Views 19046
bouhoume
bouhoume over 13 years ago
I've written a skill code that is supposed to change one of the pin names of a given cell from an old value to a new one in the schematic and symbol views. It works well on the surface but gives a warning that I have to fix: the pin name gets changed as wanted in both views but there's a warning that the pin list of the symbol does not match the pins on the symbol. In other words, although the pin on the symbol is changed, the pin name in the pin list is unchanged and I'm stumped as to how to reconcile the two.
Here's the code and if anyone has any insights on this issue, please let me know:
/* To be run on a single cell; the cell will have to be checked out first; lib and cell will be provided as argument*/
procedure(cellChangePinName(myLib myCell oldName newName)
let( ( myInstList myInstances myInst mycv myListOfNets myNet)
        ;cv=geGetEditCellView()
        if(!dbOpenCellViewByType(myLib myCell "schematic" "schematic" "a" )==t then
                printf("\nCell is unwritable, make sure it's checked out and try again\n")
        else
                mycv = dbOpenCellViewByType(myLib myCell "schematic" "schematic" "a" )
                ;mycv = dbOpenCellViewByType("temp_brou" mycv~>cellName "schematic" "schematic" "a" )
                myInstList=nil
                myInstList = setof( myInstances mycv~>instances  myInstances~>pin~>term~>name == oldName )
                ;myInstList = setof( myInstances mycv~>instances  myInstances~>pin~>term~>name == "VDD" )
                if(length(myInstList)==0 then
                        printf("\nThere are no pin names of that name in the schematic of this cell:\n%s......%s/%s\n" oldName myLib myCell)
                else
                        foreach(myInst myInstList
                            myInst~>pin~>term~>name = newName
                            ;myInst~>pin~>term~>name = "VDD_brou"
myListOfNets=setof(myNets mycv~>nets myNets~>name==oldName)
foreach(myNet myListOfNets
dbMergeNet(dbMakeNet(myNet~>cellView newName) myNet~>term~>net)
myNet~>name=newName
);foreach
                        );foreach
schVIC(mycv)
                ;dbSave(mycv)
                dbClose(mycv)
                );if
        );if
if(!dbOpenCellViewByType(myLib myCell "symbol" nil "a" )==t then
        else
mycvS = dbOpenCellViewByType(myLib myCell "symbol" nil "a" )
            myInstList=nil
            myInstList = setof( myInstances mycvS~>shapes  myInstances~>pin~>term~>name == oldName )
                printf("\nThere are no pin names of that name in the symbol of this cell:\n%s......%s/%s\n" oldName myLib myCell)
            else
myNet~>name=newName
);foreach
                );foreach
schVIC(mycvS)
;dbSave(mycvS)
dbClose(mycvS)
            );if
        );if
);let
) ;proc
  • W Relyveld
    W Relyveld over 13 years ago
    Hello Bouhoume,
     I think you need to check if the new name is a valid net and terminal. If not you need to create them. As example:
    Net = dbFindNetByName( Cell newName)
    unless( Net Net = dbCreateNet( Cell newName))
    Term = dbFindTermByName( Cell newName)
    unless( Term Term = dbCreateTerm( Net newName IOType))
     You need to define IOType ( "input" etc. ) Cell is mycv.
    Greetings, William
