  3. QRC menu does not load
  • Replies 7
  • Subscribers 130
  • Views 17057
Kabal
Kabal over 13 years ago
I posted similar question in an old existing thread, I am not sure probably I should have post it in a new thread dedicated just to this.
We have EXT10, the qrc version is: 10.1.1-p095
The assura is 4.1, 6.13
In the .cshrc I have:
setenv ASSURAHOME $cadence_install_dir/assura41
setenv QRC_HOME $cadence_install_dir/ext10
And the path to internal folders of ext10 and assura41. However I also do get:
*WARNING* The RCX UI context file is already loaded.
The Linux which we are using is an updated new version of RHEL. what else could I be missing?
  • Quek
    Quek over 13 years ago
    Hi Kabal
    You need to ensure that your version of Assura must be at least 41USR1_HF9. Detail version info can be obtained using:
    terminal>assura -W
    Please see COS solution 11677778 for more details.
    Best regards
    Quek
  • Kabal
    Kabal over 12 years ago
    well, here is what this command returned me:
    sub-version 4.1
    and qrc -version returned:
    Name : qrc - Cadence Extraction QRC - (32-bit)
    Description : Parasitic Extractor
    Version : 10.1.1-p095
    Build Ref. No. : 095
    IR Build No. : 095
    And I guess this one a version which supposed to work, right? What other problems can be there?
  • Quek
    Quek over 12 years ago
    Hi Kabal
    No, this is not a vresion that is supposed to work. It looks like your version of Assura is too out-dated. You should be able to resolve the problem by installing the latest version Assura. I am using the following:
    terminal>assura -W
    sub-version 4.1_USR2_HF21
    You need to use a version of at least "sub-version 4.1_USR1_HF9".
    Best regards
    Quek
  • Kabal
    But how is that version called in Cadence install directory? Because they are called usually like for example:
    Base_ASSURA04.10.001-613_lnx86
    So which one should I choose? (in other words which one corresponds to 4.1_USR1_HF9 or 4.1_USR2_HF21)
  • Quek
    Hi Kabal
    You can use this version:
    30 Nov 2012 ASSURA04.12.021, Version: ASSURA41USR2HF21OA_615
    If you are using IC613 and would like to use a version that matches the version of Virtuoso, you can use this version:
    11 Oct 2010 ASSURA04.10.018, Version: ASSURA41USR1HF13OA_613
    Best regards
    Quek
  • Kabal
    I have installed newer version, But now even assura menu does not load (not only QRC), and here is what I see in the CIW:
    *WARNING* dlopen: /home/soft/cadence/assura41/tools.lnx86/assura/lib/libavview.so: /home/soft/cadence/ic614/tools/lib/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /home/soft/cadence/assura41/tools.lnx86/assura/lib/libavview.so)
    *WARNING* Failed to open shared object file /home/soft/cadence/assura41/tools.lnx86/assura/lib/libavview.so
    *WARNING* (LE-104272): Assura has not been installed in this hierarchy.
    The package libstdc++.so.6 does exist
    Also, I checked that my current libstdc++ supports version: GLIBCXX_3.4.11
    Then how come CIW complain? Maybe broken link of some sort? but if yes then where?
  • Quek
    Hi Kabal
    Would you please provide the following info by executing the cmds in the working directory that has cds.lib file?
    terminal>assura -W
    terminal>assura -V
    terminal>virtuoso -W
    terminal>env | grep ASSURAHOME
    terminal>egrep "avTech" cds.lib
    terminal>cat /etc/redhat-release
    Please also upload the output of the following cmd as a file attachment.
    terminal>rpm -qa > rpm.log
    Best regards
    Quek
